Another Dagas bottle ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-19-2019, 08:12 AM Thread Starter
Beatngu's Avatar
I did a search and couldn't quite find my particular situation for an answer.
Anyway I have a 08 97k miles. MPD Single turbo setup , Mishimoto radiator and IC, Byall tuned. Old degas bottle without the update venturi T fitting. I can drive for hours no issues , hot or cold weather. Even the occasional wot pull. But twice now out of 6-8 trips taken coolant has puked out of the degas bottle. I bought a Stant cap with no fix. The 2 times it did puke I was a little harder on it , hit the Rev limiter bc the trans was shifting late. Coolant never gets over 190s, exhaust runs clean. Before I assume it's heads gaskets could it be the old degas bottle?
2016 AG GT350
2013 Fresh150
2008 F350 Lariat Stroker
2005 F250 Lariat Stroker
2004 Mach1 6 spd Black on black
DSS 5.0L stroker
Comp cams w/ FRPP ported heads
twin Turbonetics
13psi 749 hp / 620 ft. lbs. @ 16*
E85 numbers to follow
old Kenne Belle setup at 16 psi
and so on......
600 hp / 585 ft. lbs.
Beatngu is offline
post #2 of 6 Old 07-19-2019, 10:19 AM
Quoted: 23 Post(s)
How full are you filling it? Older bottles like yours and mine the hot fill level was higher. The “full mark” should be full when hot. Instead of cold. They will puke if it’s above that line when hot. They lowered the line with the later job models
colesalisbury01 is offline
post #3 of 6 Old 07-19-2019, 11:18 AM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 603 Post(s)
Easy way to tell... Hook a pressure gauge up and go do a couple wot pulls. If pressure spikes with throttle, you have your answer.
2015 F350 SRW CCSB Lariat - Stock, for now
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, Egr delete with BD intake elbow, SCT X4 with tunes from Tyrant Diesel, Monitored by CTS, Fox 2.0s. - SOLD
-Matthew
CrazyS0b is offline
post #4 of 6 Old 07-19-2019, 12:22 PM Thread Starter
Beatngu's Avatar
hopefully Monday I'll have a chance to try this
2016 AG GT350
2013 Fresh150
DSS 5.0L stroker
twin Turbonetics
and so on......
Beatngu is offline
post #5 of 6 Old 07-21-2019, 09:11 AM
RandomForumGuy's Avatar
Quoted: 218 Post(s)
Garage
+1. You do not know how long it took me to figure that out.
RandomForumGuy is offline
post #6 of 6 Old 07-22-2019, 08:24 PM Thread Starter
Beatngu's Avatar
Just a update , thrashed on it harder than I have in the past tonight with a pressure sensor hooked to the degas. Max psi I seen was 16.5 and it never puked. Idk what was causing it , maybe just gen 1 degas bottle and little to much coolant. I'll sleep better tonight.
2016 AG GT350
2013 Fresh150
DSS 5.0L stroker
twin Turbonetics
and so on......
Beatngu is offline
