loud knock noise - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By djmaguire
post #1 of 3 Old 06-23-2019, 08:10 PM Thread Starter
loud knock noise
I just got auction 2010 f250 and the engine has loud knock on idle. Looks like previous owner neglected to do oil changes and caused loud knock. The engine is fully deleted. I wonder what is best way to diagnose the issue? Would bad lifters give loud knock noise ? What else could be wrong with it ? What cost to replace lifters?
tritron is offline
post #2 of 3 Old 06-23-2019, 08:23 PM
Quoted: 7 Post(s)
It may be a natural sound as well. Ford did release a TSB about a tapping sound for the 6.4. If it disappears with speed then it’s common. Rocker arms can typically be heard as a “popcorn” coming from intake.
colesalisbury01 is offline
post #3 of 3 Old 06-24-2019, 01:01 PM
djmaguire's Avatar
Quoted: 1568 Post(s)
Garage
Here is the TSB.
For this sort of problem, making a video so that we can hear the knock may be your best plan of action. Given your post count, your best bet is probably uploading it to YouTube and then posting a link that is slightly disguised.
Ex: w w w . you tube . com/ XuiR5E8 (remove the spaces).
File Type: pdf 2012-08-14_061126_2008_ford_f-350_super_duty_engine_noise.pdf (65.3 KB, 14 views)
SparkyF250 likes this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is online now
