6.4 no start after engine rebuild - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-19-2019, 04:39 PM Thread Starter
Quoted: 5 Post(s)
had to buy a reman longblock engine. did the swap and everything went well. primed up the fuel and oil but the truck will not start from the cab via the key cranking. I have to turn the key on and go out to the starter wire by the passenger battery, jumping power from the batter to the starter and it will crank for 5-10 seconds before firing off, then will run fine and shut off again via the key from the cab. anyone have any thoughts or ever have this issue? I have the dpf and egr deleted but no tuner yet so I do have a bunch of codes due to that but still don't know or think its enough to not let start from the cab! please help!
greygoose08 is offline
post #2 of 4 Old 01-19-2019, 05:36 PM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 603 Post(s)
If its deleted you will need a tuner for the truck to run... The pcm will lock you out.
2015 F350 SRW CCSB Lariat - Stock, for now
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, Egr delete with BD intake elbow, SCT X4 with tunes from Tyrant Diesel, Monitored by CTS, Fox 2.0s. - SOLD
-Matthew
CrazyS0b is offline
post #3 of 4 Old 01-28-2019, 02:07 PM Thread Starter
Quoted: 5 Post(s)
ok well I put back in my other ecm which has a single tune on the ecm itself and the truck will fire up now. I had it firing normal (in park) but now I can only get it to fire and crank when the trucks in neutral???? I took it out for a little drive to test everthing out, and noticed my speedo, coolant temp not working, and lack of power. so I thought to put in my other TCM thinking for some reason that maybe just maybe the speedo was tied into the tcm. well it wasn't, actually lost communication with the tcm and had to ohm out the whole harness and check every fuse over before finally getting power back to the tcm, but now it only cranks and fires in neutral. does anyone have an idea on this issue?? any help greatly appreciated before I have to take it to the dealer and get taken for there
post #4 of 4 Old 12-05-2019, 08:35 PM
The Stock Tune looks for EGR & DPF signals before it will start the motor.
One has to re-flash the ecm and state that the emissions are gone.
If you leave the base tune in place at this point in time, the check engine light comes on after a short while of driving with a missing EGR code error. With the Mini Maxx you can clear this code while driving.
To get the code to go away, you must use one of the H&S specific tunes that then ignore the EGR circuit altogether.
The different tuners will have have slightly different options.
sbc97281 is offline
