Who is running Mishimoto radiators - Ford Powerstroke Diesel Forum
 10Likes
post #1 of 143 Old 08-05-2014, 11:27 PM Thread Starter
Just curious with all the new information on the cause of mishimoto radiator failures (front cab mount bushings), how many miles do you have on your Mishimoto radiator? Ive just purchased one and was very dissapointed to see the recent discussions on their failures, I assumed (I know!) it was end all fix as they advertised. I have not installed it yet, waiting on cab mount bushings to come in before install. I spoke with a Ford parts rep. today and he told me that Ford has a replacement radiator that has resolved all the 6.4 rad. problems.......If thats the case, then why is that no one else can make one? Mishimoto? I did watch the video about cab flex..I'm no engineer but it seems pretty simple to make a radiator that can be mounted a little different to reduce stress, maybe better bushings, there has to be something. Maybe my shop guy will have some ideas. I really hope that I didn't spend almost a grand on something that has to replaced every 5000 miles.
So has anyone had good luck with them, if so how many miles?
markperro2 is offline
post #2 of 143 Old 08-06-2014, 03:50 AM
hoofdoctor's Avatar
SUBSCRIBED...........
Oh boy! I had an over heat last week pulling through the black hills and suspect I need a radiator due to a leak I can't find. I sure don't want to order and install yet another failed radiator!
markperro2 likes this.
hoofdoctor is offline
The Following User Says Thank You to hoofdoctor For This Useful Post:
markperro2 (08-08-2014)
post #3 of 143 Old 08-06-2014, 06:08 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I installed my moshimoto in January of this year. So far no problems (knock on wood). This information about the body mounts is new so next time my cab is up I will be replacing them.
04hdfatboy is offline
The Following User Says Thank You to 04hdfatboy For This Useful Post:
markperro2 (08-06-2014)
post #4 of 143 Old 08-06-2014, 08:55 AM
08stroker250's Avatar
Look in to Aldraco.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
The Following User Says Thank You to 08stroker250 For This Useful Post:
post #5 of 143 Old 08-06-2014, 10:07 AM
hoofdoctor's Avatar
Originally Posted by 08stroker250 View Post
Look in to Aldraco.
Aldraco? Can you explain what I'm looking into?
The Following 2 Users Say Thank You to hoofdoctor For This Useful Post:
JAcktheBear3 (12-17-2014), markperro2 (08-08-2014)
post #6 of 143 Old 08-06-2014, 10:12 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Its another option. They also make an all aluminum radiator for the 6.4.
post #7 of 143 Old 08-06-2014, 10:39 AM
hoofdoctor's Avatar
I'll check it out 04hd.......thanks for the tip!
post #8 of 143 Old 08-06-2014, 07:59 PM Thread Starter
I did consider alradco, went with Mishi due to their presence on this forum, seems like good customer service. My concern is not the quality of radiator, more so the cause of failure being the mounts and frame of the truck. It just seems that there has to be a better way to mount the radiator to prevent stress points.
post #9 of 143 Old 08-08-2014, 01:42 PM
Supporting Vendor
Mishimoto's Avatar
Quoted: 74 Post(s)
We completely understand your skepticism regarding radiator replacement. We recently investigated a 6.4L in an attempt to identify any components that may be resulting in the recurring radiator failures that many owners are facing. Based on our findings, we were able to develop a checklist for TSB related components and maintenance items that will impact the longevity of your radiator. Our goal is to inform the community and help improve radiator lifespan. We highly recommend reviewing the items on this list prior to radiator installation (Both OEM and Mishimoto). Check out the article below.
6.4L Powerstroke Maintenance You Must Perform! | Mishimoto Engineering Blog
Thanks for the feedback! Check out those mounts when you have a chance, they seem to be a common failure point.
Thanks for the kind words Mark! We enjoy spending time within the enthusiast community.
Mishimoto is offline
The Following User Says Thank You to Mishimoto For This Useful Post:
post #10 of 143 Old 08-08-2014, 01:51 PM
ZMANN's Avatar
Quoted: 3875 Post(s)
Look in to Aldraco.
it's ALRADCO
I have a Performance brand aluminum with crimped tanks from BPD in my 6.0 but I would have gone Mishimoto in a heartbeat had I seen the affordable ebay seller prices
if I had a 6.4 I would be looking at the cab mounts and also modifying the RAD mount to allow more movement of the attachment area without it tweaking the RAD
6.0 flush pdf
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
