H&S tuner problem - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By isellrareunicorndna
post #1 of 6 Old 12-27-2019, 06:44 AM Thread Starter
H&S tuner problem
Yesterday I purchased an F450 with a 6.4. It has an H&S tuner in the center console, so I hooked it back up and put the stock tune on it. Every time I shutdown the truck, I need to reinstall the stock tune for the truck to start. The truck will not start with an H&S tune, only the stock tune and only after a fresh retune!
A vn-tech is offline
post #2 of 6 Old 12-27-2019, 11:11 AM Thread Starter
I found the problem. I was installing the tune with the EGR still on the vehicle. When I put the tune in with the EGR removed, it took the Tune and starts fine now! I will report back if I run into any more problems. Thanks
post #3 of 6 Old 12-27-2019, 11:29 AM
Dales Super Store's Avatar
Quoted: 35 Post(s)
Glad you sorted it out.
844-487-2787
us for special pricing
Operating Hours: 9am-6pm EST Monday - Friday
Dales Super Store is offline
post #4 of 6 Old 12-28-2019, 06:47 AM
SeaPig's Avatar
Garage
Good for you. I am currently in the process of doing an EGR delete on my ‘08 F-450.....”finally”.
Wow is it a slow process for me, but have received EXCELLENT advice.
2008 JOB I F-450 DRW, LWB, CC, 4:88's
Spartanized
SeaPig is offline
post #5 of 6 Old 01-05-2020, 11:39 AM
Quoted: 2 Post(s)
I had the same problem had to learn the hard way not to go to ford
midnightrider79 is online now
post #6 of 6 Old 01-08-2020, 04:55 PM
Quoted: 14 Post(s)
Just a heads up. Once you pull everything and flash the system for the first time - you’ll likely get the red wrench indicating a problem.
This should occur BEFORE starting engine. Key on engine off. If memory serves me correctly.
I had this issue - and asked for help here in the forum. Thankfully a quick reply stating to install the hot tune solved the issue. About 15k since that time and no issues. Well a water pump but I think that’s unrelated.
Search my posts if you encounter this for exact details. I went through this a year or so ago
Sent from my iPad using Tapatalk
midnightrider79 likes this.
isellrareunicorndna is offline
