For "ya old" Spartan guys - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-08-2019, 09:00 AM Thread Starter
SeaPig's Avatar
Garage
Howdy from Houston.
Is there anyone still on here that purchased and installed Spartan tunes.....many years ago?
The question I have if you did is, did Spartan take away the file extension NEGR, (EGR Delete files), in their naming extensions, and rolled the NEGR naming conventions into the DPF-1, DPF-2 ect files?
The reason I ask is I have had these tunes for years and am finally getting around to taking the EGR and DPF off the vehicle, and want to make sure that when I get to that point, I load the correct tune that deletes both the DPF and EGR at the same time.
Thank you
V/r
Michael
2008 JOB I F-450 DRW, LWB, CC, 4:88's
Spartanized
SeaPig is offline
post #2 of 4 Old 12-10-2019, 06:48 AM Thread Starter
SeaPig's Avatar
Garage
Just to add on to this thread, here are the specific Spartan tow tunes I am referring to:
210HP_2_TP_NEGR.gtf
210HP_2_TP.gtf
210HP_2_NEGR.gtf
210HP_2.gtf
210HP_1_TP_NEGR.gtf
210HP_1_TP.gtf
210HP_1_NEGR.gtf
210HP_1.gtf
I apologize for all of the writing folks. I am just hoping someone still on here will recognize these tunes and help me with the decision on which one to load to get both the DPF and NGR turned off.
Thank you for the patience.
V/r
Michael
Spartanized
SeaPig is offline
post #3 of 4 Old 01-15-2020, 06:37 PM
Quoted: 3 Post(s)
Is this version 7 files? Im running the same 210 Spartan tunes. I started with the 210 then changed to 210tp. Each one I had to select the "edit tune" tab to turn the egr off. Any tune 210 and below the egr is on. 250 abd above its automatically turned off.
2010 Ford F250 CrewCab SWB 4X4 Lariat.
4Ē Powerstroker67 Downpipe
5Ē Flopro SS w/ Cat & Muffler Delete
RCD EGR delete
Spartan/Patriot Ndash currently on 210TP tune
Mudbugs is offline
post #4 of 4 Old 01-16-2020, 03:16 AM Thread Starter
SeaPig's Avatar
Garage
As I finally figured out, looking at the files on a computer and looking at them on the DashDaq are COMPLETELY different things.
I must have the version right after that as it is giving me the option to turn EGR off even on the lower tunes.
Thanks for the response.
Spartanized
SeaPig is offline
