BulletProof Diesel Full Oil Cooler Install and Review - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 24 Old 05-16-2017, 04:06 PM Thread Starter
Justinlw's Avatar
Quoted: 157 Post(s)
Send a message via MSN to Justinlw
*Disclaimer*
I installed this kit and a single turbo kit at the same time. My instructions and order of tasks was a little altered, so I can't speak a whole lot to the accuracy of the instruction manual.
To do this job in it's entirety, I would recommend setting aside a full weekend. Though it wasn't particularly difficult, getting at some of the components cab-on can be time consuming.
The overall concept of the kit, hose routing, bracketry, and components are excellent. One small detail of that is a little tricky. The kit is designed to use the OEM oil cooler brackets to secure the oil lines to the cooler. My cooler and brackets seem to have disappeared, so it took a little extra effort to ensure the oil pressure line did not contact any body mounted accessories. Failure to route this hose away from body parts WILL leave you with a loud in cab whine. Ask how I know.
The kit includes a top plate that bolts to a new OEM oil cooler. As the oil cooler remains the same, there is no gain in efficiency over stock. What you do gain is a better oil filter with no bypass, and an easily serviceable oil cooler should it ever plug again.
Andrew at BPD has been awesome to work with, and has answered all of my questions and issues. All in all, I would recommend this kit to anyone in need of a new cooler. Is it worth doing if you're not seeing delta issues? Probably not.
SparkyF250 and Beerent93 like this.
Justinlw is offline
post #2 of 24 Old 06-01-2017, 05:28 PM
Quoted: 2 Post(s)
Looks pretty good. Hows it run? Any change in temps?
dirtyharry44 is offline
post #3 of 24 Old 06-01-2017, 05:35 PM Thread Starter
Justinlw's Avatar
Quoted: 157 Post(s)
Temps are basically the same. It's an OEM cooler in a different location. It does add some coolant and oil capacity (about 3qts of oil to fill new filter, cooler, and hoses), and eliminates the filter bypass. My only complaint so far is that you can hear the oil pump pulse at certain temps and rpms as a slight whine. Nothing too crazy, just enough to note.
SparkyF250 likes this.
Justinlw is offline
post #4 of 24 Old 06-02-2017, 05:54 AM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
The oil pump pulse is a common complaint with the BPD kits. Its because of the lines and contact with the body. The 6.0s do it to.
I also just finished this kit on mine. Still waiting for approval to post pics and info. I went all flat rate on mine and did the install in about 4hrs cab on.
toren302 is offline
post #5 of 24 Old 06-02-2017, 06:00 AM Thread Starter
Justinlw's Avatar
Quoted: 157 Post(s)
There's no contact with any body parts here, I added a 45* at the cooler to help clear the degas bottle also. Been discussing with Andrew. It's down to a minimum at a couple areas in the rpm range, I think I'm hearing resonance from the hose itself. Either way, it isn't bad at all.
Justinlw is offline
post #6 of 24 Old 06-02-2017, 06:02 AM
djmaguire's Avatar
Quoted: 1586 Post(s)
Garage
... I went all flat rate ...
That made me laugh. ...and four hours. Day-um.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #7 of 24 Old 06-02-2017, 06:08 AM
Bump To Pass!!
toren302's Avatar
Well the cooler is mounted to the master directly and yes I know it has the 3 rubber isolators, but the pulsation is transferred through from there. Ask him about the 6.0's and he will tell you the same issue with them. Its just something you have to live with. Done plenty of the 6.0 kits and only about 10% of the customers even notice it.
toren302 is offline
post #8 of 24 Old 06-02-2017, 06:25 AM Thread Starter
Justinlw's Avatar
Quoted: 157 Post(s)
Seems I'm always one of those 10%! I had the same issue on a couple other cars I've had and was able to isolate it out. I'll play with it some more when I have time. Right now I'm just glad my oil is below 230*.
Justinlw is offline
post #9 of 24 Old 06-02-2017, 06:52 AM
Heavy_GD's Avatar
Quoted: 3122 Post(s)
Garage
Feedback Score: 4 reviews
Seems I'm always one of those 10%! .
The first step is admitting it.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #10 of 24 Old 06-02-2017, 08:14 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 2643 Post(s)
Enthusiasts usually are lol.
2017 F250 CCLB KR "Nighthawk" Edition.....goodies to come.
nighthawk285 is offline
