White smoke and diesel out tailpipe - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-18-2020, 01:50 AM Thread Starter
I have a 2008 f250 what happens is when it warms up it starts to smoke white a lot. Also wet on the tailpipe from diesel and smells like diesel. But not sure what to do about it need help. Thanks!
Cfrench19 is offline
post #2 of 5 Old 01-19-2020, 09:24 AM
Quoted: 3 Post(s)
Do you have any codes?
estoppel101 is offline
post #3 of 5 Old 01-19-2020, 10:10 AM Thread Starter
I have the following codes
P2463,p2452,p2453,p246c,p2263
post #4 of 5 Old 01-19-2020, 12:17 PM
RandomForumGuy's Avatar
Quoted: 219 Post(s)
Garage
Your dpf took a huge dump on you is what it looks like from the codes
RandomForumGuy is offline
post #5 of 5 Old 01-19-2020, 03:35 PM
Quoted: 530 Post(s)
Garage
Clear the codes and see if new ones popup
looks like the pressure sensor is bad
Also short trips in cold weather will cause the DPF to need to regen more often
Here is a vid of a forced regen
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
