Stock boost levels - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-20-2019, 07:32 AM Thread Starter
Stock boost levels
What should a stock 6.4 put out for boost? When driving the truck it feels like the motor is working, but not accelerating as I feel it should. It almost feels like the exhaust is plugged, but I'm not getting the dpf clean message.
Sent from my SM-G965U using Tapatalk
bigboytoys89 is offline
post #2 of 3 Old 05-20-2019, 12:05 PM
Quoted: 63 Post(s)
My 08 is all stock and puts out close to 40psi at full throttle. I normally don't go much over 20-25psi daily driving though.
onecrazyfoo4u is offline
post #3 of 3 Old 05-20-2019, 12:08 PM
Quoted: 63 Post(s)
Do you have a monitor to see when the dpf is cleaning? EGT's will go from the normal 400-500 deg F up to 1100 F during the 10 minutes or so of cleaning. If you don't have a monitor you can press the button to check system status or whatever the control page says (above odometer). It'll cycle through systems and tell you if it's "cleaning exhaust filter".
Similar Threads
Thread Thread Starter Forum Replies Last Post
Build Thread: TowBoss F350 6.0L PSD. colo_dually General 6.0L Discussion 71 03-11-2018 01:01 PM
06 Slow to Boost notaslow6.0 6.0 Motor problems 1 06-19-2017 03:53 PM
Random no boost, long crank, no codes. tesmith66.0 6.0 Motor problems 8 05-01-2017 02:37 AM
Low power normal boost stock confused? Early99 Ron 99-03 7.3 Motor Problems 26 02-12-2017 07:11 PM
Stock Boost? SUPER60omni 99-03 7.3L General Discussion 2 10-15-2006 06:38 AM
