cluster question - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 6 Old 12-23-2019, 11:30 AM Thread Starter
texasstroker's Avatar
Quoted: 5 Post(s)
cluster question
Not sure if this is the correct location or not. Done a little searching and havent seen much.
Got another 2009 F250 XLT diesel in over the weekend with 140-k miles on it. some of the dash lights and some of the gauges are not working. Got a couple of prices to repair this BUT I need to use this truck. Can I use a cluster out of another truck until I original cluster back? Or do these need to be programmed to work?
texasstroker is offline
post #2 of 6 Old 12-23-2019, 07:37 PM
RandomForumGuy's Avatar
Quoted: 219 Post(s)
Garage
I am fairly certain they need a reprogram to work with the new truck. I remember seeing an article where the pcm stores some info on the cluster and if it doesnt match it wont work. But i could be wrong. You could buy a used one and have ford tune it to your truck and skip the gauge rebuild all together
RandomForumGuy is offline
post #3 of 6 Old 12-26-2019, 09:16 AM Thread Starter
Quoted: 5 Post(s)
If I wasn't interested in keeping the miles on this truck I would do that. BUT this truck has good miles and that is why I need to keep this cluster. Just really needed to use this truck to pull a trailer with cause my main truck in in the body shop and the only other truck I have usable right now is 2 half tons....
But Thanks for the info.
post #4 of 6 Old 12-26-2019, 10:31 AM
Quoted: 219 Post(s)
Garage
Ford has software that can change the mileage on a cluster...
post #5 of 6 Old 12-26-2019, 12:59 PM
partyman97_3's Avatar
Quoted: 913 Post(s)
Garage
I don't know the answer to your question,, but you could give circuit board medics a call and they will be able to tell you. Several guys on here have used them, they come well recommended. I had mine repaired from my 2003, but its not a daily driver so i wasn't in a big hurry for it.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
The Following 2 Users Say Thank You to partyman97_3 For This Useful Post:
texasstroker (12-27-2019)
post #6 of 6 Old 12-27-2019, 09:27 AM Thread Starter
Quoted: 5 Post(s)
That is correct, BUT as soon as they are complete it is entered at cluster change/repair and when it hits carfax or autocheck they mark it at odometer discrepancy! Already ran into this on another truck we fixed for a customer that demanded we use Ford to fix it. We did and now he is not happy because he has a $17-k truck that has a 142-k miles miles but when or if someone ever runs a carfax or autocheck report it shows up as TMU possible odometer discrepancy. I tried to explain this to him before hand and he just didnt get it.
