Mirror wiring diagram - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
post #1 of 8 Old 06-26-2019, 12:24 PM Thread Starter
Redlazer's Avatar
Quoted: 11 Post(s)
Does anyone have a diagram for 08+ mirrors wiring diagram? Iím looking to find out what color wiring for each function ex: running light, turn signal, adjustment, heat, telescope in and out, ground, and fold in and out.
Redlazer is offline
post #2 of 8 Old 06-26-2019, 12:55 PM
djmaguire's Avatar
Quoted: 1581 Post(s)
Garage
Check here:
https://www.powerstroke.org/forum/6-...onversion.html
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #3 of 8 Old 06-26-2019, 02:39 PM Thread Starter
Redlazer's Avatar
Quoted: 11 Post(s)
Thank you but it doesn’t tell me which is extended in and out and fold.
Redlazer is offline
post #4 of 8 Old 06-26-2019, 05:09 PM
djmaguire's Avatar
Garage
Okay. Then this.
2004 F550 CC Lariat
post #5 of 8 Old 06-26-2019, 05:26 PM Thread Starter
Redlazer's Avatar
Quoted: 11 Post(s)
Man thank you
Redlazer is offline
post #6 of 8 Old 07-10-2019, 10:20 AM Thread Starter
Redlazer's Avatar
Quoted: 11 Post(s)
My mirrors are from a 2011 with a 13 pin plug. My plug only has 3 wires going to it. Driver side on my plug is red, green, and, yellow. The passenger side is purple, green, and yellow. Can someone tell me what wires off my pigtail to connect to my OEM wires to so I can adjust my mirrors please? Thank you
Redlazer is offline
post #7 of 8 Old 07-10-2019, 10:23 AM
djmaguire's Avatar
Garage
Attached is the Power mirrors section of the 2011-2016 Workshop Manual. I don't know if there is a difference between that and the 2008 that I posted earlier. I am only posting them in case you need them.
You might do better here by improving on your description. The statement...
Originally Posted by Redlazer View Post
The mirrors I have are 2011s power folding and telescoping 13 pins, but my truck only has 3 wires going into them. Driver side red blue and yellow, and passenger side red, green, and yellow. Iím trying to figure out which ones go to what so my mirrors will adjust. Please help.
...isn't meaning very much to me. Info like...
Did you buy the truck with the mirrors and you are trying to get them to work or did you buy the mirrors special?
What do the three wires going into your mirrors do?
Have you identified the functions of any wires for either your controls or mirrors?
Do you have controls on the door for telescoping and folding? If so, where are the wires from those switches? If not, what is your plan to get those controls [no controls=no wires]?
Things like that.
2004 F550 CC Lariat
post #8 of 8 Old 07-10-2019, 03:30 PM Thread Starter
Redlazer's Avatar
Quoted: 11 Post(s)
Ok the OEM mirrors had a round plug and it only has 3 wires. So the plug that is on the my door harness is round with three wires. The 2011 mirrors have 13 wires in the plug. I also have the plug in that has 13 wires. Iím trying to find out what wires in need to connect/I need to do so my 2011 mirrors will adjust up, down, left, and right. The old mirrors only had adjustment, no lights, or anything else. The 2011 has adjustment, power folding, power telescoping, running lights, heat, and turn signals. Everything is hooked up except the power adjustment.
Redlazer is offline
