Radio wiring diagram - Ford Powerstroke Diesel Forum
6.4 Electronics Discussion TV's, Radios, everything electric and NON-Performance.
 1Likes
  • 1 Post By ilxter
post #1 of 5 Old 04-09-2018, 03:45 PM Thread Starter
08f3fiddy's Avatar
Does anyone have a wiring diagram for the radio. I want to install an after market radio but I am having a hard time piecing together the right plug and play harness. On the back of the factory radio I have 3 plugs. 24pin, 16pin, and 8pin connections. I know the 24pin is the main connection and the 8pin is for the sub. What is the 16pin? Most aftermarket harness do not include that 16pin connection. SIDE NOTE my factory radio will not turn on without that 16 pin connected, will I have the same problem with an aftermarket radio? There are also canbus harness's that include that 16pin harness however, I believe my vehicle doesn't have canbus, but I am not 100 percent sure on that, one person says I do the next says I don't. Any help?
08f3fiddy is offline
post #2 of 5 Old 08-11-2019, 10:32 AM
ilxter's Avatar
Quoted: 6 Post(s)
Bumbing an old thread: I have the same need. So far I have gathered that the 16-pin is (at least some of the wires) CAN and at least two wires are connected to the steering wheel remote. Having a hard time getting that to work on a new aftermarket Sony (XAV AX-100), even with a ”universal” SWC-plug-in(?) connector.
Everything else works.
For 2008 F-250 with no screen nor amp/sub for the OEM radio.
ilxter is offline
post #3 of 5 Old 08-23-2019, 06:49 AM
ilxter's Avatar
Quoted: 6 Post(s)
Wiring a new radio + steering wheel control + reverse signal
Replying to myself and perhaps to someone planning to replace the factory wormbox with a proper headunit. Make your life much, oh-so-much easier with a correct wiring harness. For my truck this is the correct oneAC Audio RP4-FD11. Needs soldering to the headunit harness, but otherwise it is a total plug’n play and everything that is supposed to work, works.
I tried the cheap way first (”universal steering wheel remote harness”, USD 90) and ended up getting the much more expensive harness anyway (approx. USD 170) as the ”universal” did not work. I did not calculate how much was shelled out for beer during the try&error-installation - probably a lot.
Hopefully this weekend I have time to dive under the truck to find a suitable route for the backup camera wire. The reverse signal comes from the CAN-BUS harness (16-pin) and that also works already (except for ”no signal from camera” as it is not connected yet).
According to youtube it is possible to hardwire the reverse wire from the fusebox also, but this is way more convenient...
ilxter is offline
The Following 2 Users Say Thank You to ilxter For This Useful Post:
ZMANN (08-23-2019)
post #4 of 5 Old 08-23-2019, 06:57 AM
ZMANN's Avatar
Quoted: 4030 Post(s)
thanks for the update
I prefer the ASWC-1 https://axxessinterfaces.com/product/ASWC-1
over the PAC units myself. most aftermarket head I have dealt with have a steering wheel input port so you may not have to do any soldering to the deck wires
the 12volt.com is my fav place for wiring schematics and install help
6.0 flush pdf
ZMANN is offline
post #5 of 5 Old 08-26-2019, 09:13 AM
ilxter's Avatar
Quoted: 6 Post(s)
I was looking at that same harness first, but went with the P A C Audio - harness, because it comes with three plugs which match the trucks harness plugs —> no need to try and find the reverse gear signal.
Had to do a bit more soldering than in a ”normal” installation, because I added the amplifier at the same time. =)
ZMANN likes this.
ilxter is offline
