Towing Degas Puke - Page 2 - Ford Powerstroke Diesel Forum
 13Likes
post #11 of 34 Old 06-15-2015, 10:13 AM
california deplorable
john galt's Avatar
Quoted: 3124 Post(s)
^^^ pretty uch what all of them said
plus I just want to make sure you know the old low line is the new full line
also I had a similar issue and couldn't find the problem, but my degas bottle had a small crack in it I could only see with it out and in the sun.
replaced it with the ONLY dorman product my truck will ever see and it has been perfect since...about 20 k thus far
whole degas bottle cost me like 30 bucks on flea bay
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
The Following User Says Thank You to john galt For This Useful Post:
Heavy_GD (06-15-2015)
post #12 of 34 Old 06-15-2015, 10:33 AM
Red-Raider's Avatar
Originally Posted by EMacsTactical View Post
Off the top of my head, I can't remember what Gaskets they were - would have to ask the installer. They aren't black onix, I know that much.
It looks like it might be easy enough to make a pressure tester to hook up to the bottle, I'll look into doing that as well.
You can get a dorman brand degas bottle and cap on Amazon for about $35. Quite a few of us on the .org are using them and have had great success.
kinnisoj and john galt like this.
Red-Raider is offline
The Following User Says Thank You to Red-Raider For This Useful Post:
EMacsTactical (06-16-2015)
post #13 of 34 Old 06-15-2015, 11:14 AM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
Exactly...
john galt likes this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #14 of 34 Old 06-15-2015, 12:52 PM
kinnisoj's Avatar
Quoted: 5 Post(s)
Yup that's were I got mine from. Nice to have a good clean bottle!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #15 of 34 Old 06-15-2015, 01:33 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 600 Post(s)
Feedback Score: 11 reviews
had a dorman for a month or so with no issues.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #16 of 34 Old 06-15-2015, 01:40 PM
Heavy_GD's Avatar
Garage
Or get one of those fancy aluminum ones
GD
Heavy_GD is offline
post #17 of 34 Old 06-15-2015, 01:57 PM
john galt's Avatar
i think I would rather replace my plastic one ten times for the same price...plus i like being able to see the level from anywhere in the engine compartment...
those are pretty snazzy though
skanj0 likes this.
I like mead
post #18 of 34 Old 06-15-2015, 02:06 PM
djmaguire's Avatar
Quoted: 1586 Post(s)
Garage
Don't do that! Buy my patented aluminum windshield washer fluid canister and vacuum reservoir set, instead!
john galt and Kdavid1 like this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLink™ LX, Autometer EGT
djmaguire is offline
The Following User Says Thank You to djmaguire For This Useful Post:
post #19 of 34 Old 06-15-2015, 02:33 PM
Heavy_GD's Avatar
Garage
LoL
GD
Heavy_GD is offline
post #20 of 34 Old 06-16-2015, 02:40 AM Thread Starter
Quoted: 6 Post(s)
how much boost are you seeing?
Is the degas low after the puke?
Boost is around 20psi and it is a bit lower, however not all that much.
EMacsTactical is offline
