ANYONE HELP PLEASE.....Wont go over 2500rpm.... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-10-2011, 12:37 PM Thread Starter
Exclamation ANYONE HELP PLEASE.....Wont go over 2500rpm....
when you first start it when it is cold it runs great. Drive about 3miles and i lose power.....i have all the low end power but no top end....when you go it starts bogging down at 2200 and wont go over 2500 when you got it to the floor....if you hold it to the floor it will blow a little bit of a white/blue smoke. the codes i found in it are as follows.....P0403,P0404,P0405,P0488,P0670,P0683,P1 102,P2262. So i cleared them and did a KOER test and got only these 3 codes. P0670,P1102,P1408. i need help i need to get this thing running i cant run my business without this truck......ANY ANSWERS
pimpingtp98 is offline
post #2 of 5 Old 06-10-2011, 01:07 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Is this a late-build 2004 model year truck by any chance?
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #3 of 5 Old 06-10-2011, 01:34 PM Thread Starter
The year of the truck is 12/03
post #4 of 5 Old 06-10-2011, 08:41 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
The codes highlighted in bold red are the most likely cause of the symptoms you describe. If I were to take an educated guess, I would say your EGR throttle plate is closing randomly (or is stuck closed), causing an air intake restriction and starving the engine for air. Your easiest first step would be to remove the actual throttle plate itself to see if it improves.
m-chan68 is offline
post #5 of 5 Old 07-03-2011, 04:11 AM Thread Starter
excellent guess man. that is what it was i removed the throttle plate and it runs great....Thanks for the help
