2005 f250 6.0 113,000 looks all factory - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By voodooridr
  • 2 Post By neill1980
post #1 of 8 Old 01-28-2020, 10:29 AM Thread Starter
was accelerating while passing at about 70 no load at all pop then could hear air like a tire just lost pressure allot of white smoke 0 psi on boost limped 20 miles home loss of power started in morning to try and figure out white smoke drove down the block died no start now any thoughts
i removed and checked boots on hot side cold is plastic top side isnt blown off or the intercooler side tried to clean egr i was thinking the turbo any ideas
neill1980 is offline
post #2 of 8 Old 01-28-2020, 10:42 AM
Quoted: 515 Post(s)
Check the Charge Air Cooler (it really isn't an Intercooler) seams for a seal that "popped out".
Check the up-pipe and y-pipe bellows also.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
The Following User Says Thank You to bismic For This Useful Post:
neill1980 (01-28-2020)
post #3 of 8 Old 01-28-2020, 11:26 AM
voodooridr's Avatar
Quoted: 1083 Post(s)
Pull that plastic cold side CAC and inspect all the nooks, crannies and seams then toss it in the recycling bin and replace it with a metal one
Even if it's not split because it will eventually
Sent from my SM-G960U using Tapatalk
bismic likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
The Following User Says Thank You to voodooridr For This Useful Post:
post #4 of 8 Old 01-28-2020, 11:37 AM
R&Rpowerstroke's Avatar
Quoted: 108 Post(s)
Garage
Check your intercooler as well, mine blew apart.
03 250 ccsb blue spring, UCF ported and polished heads, Odawg SR3, ficm tuner, SCT x4 with custom tunes, 4" turbo back to 6" tip, Magtec diff covers, Amsoil fluids, ARP 625's, Airlift bags, Kc stage 1, Dieselsite hpop, Vision Hauler 19.5's, No Limit intake, full on board air with 8.5 gallon tank, train horns, Sinister degas, DieselSite water pump, Big Wig rear sway bar, 7.3 clutch fan, BPD adapter
Wife's new ride 2019 F450 Lariet Ultimate CCLB 4x4
R&Rpowerstroke is offline
The Following 2 Users Say Thank You to R&Rpowerstroke For This Useful Post:
post #5 of 8 Old 01-28-2020, 01:33 PM Thread Starter
thanks guys i will do that i just bought the truck seems to be a good solid truck and i have discovered the 6.0 has some flaws i am going to upgrade
ChrisSki and voodooridr like this.
post #6 of 8 Old 01-28-2020, 02:12 PM
ZMANN's Avatar
Quoted: 4034 Post(s)
betting it is more than a CAC issue
6.0 flush pdf
ZMANN is offline
post #7 of 8 Old 01-29-2020, 10:33 AM Thread Starter
i was thinking maybe the turbo but im hopeing not well sort of i plan to replace it regardless but it was more towards the end of things i wanted to do not for sure but assumeing i dont have any major issues i thought i should start with head gaskets and arp studs and work my way through to oil cooler kit high performance intercooler and pipes then i was thinking maybe exhuast y pipe turbo and air breather and so on
post #8 of 8 Old 01-29-2020, 10:36 AM Thread Starter
and of course egr delete
