Cranking, but no start - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 14 Old 01-20-2020, 08:50 AM Thread Starter
My buddy gave me a 2003 f250 xlt 6.0 , it wasnít running when i got it. He told me that the dealer told him lpop had scowling and needed to be swapped. Iíve replaced the Lpop and there were signs of scowling, front cover and water pump Bc it came in kit, 2 new batteries 700cca each, upgraded to 6.4 starter, new detent spring(the one in it was in 3 pieces), new temp sensor, the fuel system is aftermarket, heads been studded almost completely bullet proofed, upgraded coolant system, new motorcraft oem filter and 15w40 motorcraft oil as well as oil cap is eom too, all glow plugs are good, no check engine light, and Iím still not getting any oil up to the filter. It cranks and cranks but it just wonít turn over. My buddies been helping me w the build he works on 6.0ís here in Texas and itís not cold here if anyone was think itís the temp. Please i need some other ideas ive spent 1700$ alone in parts and my buddy has a snap on obd2 reader that shows him almost everything Iíve run out of ideas and so has he. I think if no oils coming to the filter that maybe there could a mass leak on the motor somewhere else , also this is my first post so trying to be descriptive. Thank you to all who comment please and thank you !
JRo_6.Slow is offline
post #2 of 14 Old 01-20-2020, 09:45 AM
Quoted: 512 Post(s)
Did you replace the front cover?
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 14 Old 01-20-2020, 11:19 AM
skifter22's Avatar
Quoted: 4 Post(s)
Garage
No start troubleshooting guide:
https://www.powerstroke.org/forum/6-...condition.html
I've used it a couple of times and it's led me right to my problem. Follow it step-by step (even check things you "know" are ok - that's ended up being my problem before) and you'll get to the source of the problem.
bismic and bc_vickers like this.
150k+
Blue Spring
SCT Livewire w/ EGT (Street Tune)
IPR Gen3 EGR Delete & Coolant Filter
FX4 Option
Tow Package
Daily Driver
skifter22 is offline
post #4 of 14 Old 01-20-2020, 04:57 PM Thread Starter
Yes i replaced front cover a oem from Ford
post #5 of 14 Old 01-20-2020, 07:40 PM Thread Starter
thank you, i will go through this process and let yíall know the verdict when i get time unfortunately my schedule is crazy so as soon as i know i will leave the ending results after
skifter22 likes this.
post #6 of 14 Old 01-20-2020, 07:41 PM Thread Starter
@skifter22 ^
post #7 of 14 Old 01-20-2020, 07:41 PM
Quoted: 512 Post(s)
Have you checked the oil pressure regulator by the harmonic balancer?
Mark
No-start thread:
bismic is offline
post #8 of 14 Old 01-20-2020, 07:42 PM Thread Starter
@bismic Iíll check, i talked to my buddy and he said mine doesnít have the blue spring because itís been upgraded! Iíll check tomorrow . Thanks for the feedback everyone
post #9 of 14 Old 01-20-2020, 07:46 PM
Quoted: 512 Post(s)
Not sure what you mean by "top regulator".
When you remove the oil filter cap and crank (best to do it after removing the FICM relay, OR crank w/ the starter solenoid wire jumpered to the passenger + terminal), how quickly will the oil filter housing fill?
Mark
No-start thread:
bismic is offline
post #10 of 14 Old 01-20-2020, 07:48 PM Thread Starter
No oil is getting to filter
