2006 rear end issues - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By G8orFord
post #1 of 4 Old 01-19-2020, 10:08 PM Thread Starter
stevekjelland's Avatar
New to me 2006 F350. Have had the rear pinion seal replaced twice in 6 months at a local shop. Noticed was a bit louder then normal yesterday so figured change the fluid since I haven’t done it yet and discovered this surprise. Best I can guess is the pinion nut was loose at some point?? Checked the torque best I could and seems tight.
ID:	727325   Click image for larger version
ID:	727327   Click image for larger version
stevekjelland is offline
post #2 of 4 Old 01-20-2020, 06:02 AM
G8orFord's Avatar
Quoted: 2607 Post(s)
Garage
A bearing has sh!t the bed.
Yahiko likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #3 of 4 Old 01-22-2020, 11:25 AM
Quoted: 16 Post(s)
I am dealing with one right now that is making silver oil after a pinion seal replacement.
The shop that did the work does not seem to want to own the problem.
Sean
Yahiko is offline
post #4 of 4 Old 01-22-2020, 05:48 PM
Quoted: 1468 Post(s)
Feedback Score: 4 reviews
What he said. Bearing is toast.
