Rebuild advice - silver flakes in oil filter - Ford Powerstroke Diesel Forum
 11Likes
  • 4 Post By bismic
  • 3 Post By ZMANN
  • 2 Post By JRo_6.Slow
  • 2 Post By Yahiko
post #1 of 6 Old 01-17-2020, 01:54 PM Thread Starter
Cut open the oil filter when I changed the oil last week and found a handful of silver flakes in the pleats. The flakes were tiny w/ the exception of 2 that were about 1/8 the size of a pencil eraser. Truck currently runs great
Assuming a total rebuild is in my future, should I go ahead and tear down the motor now, or just continue driving the truck until failure?
My plan for the rebuild is 0.030 bore, 190cc injectors, bigger turbo, upgraded fuel system, etc... Also, there is a leak at rocker box so would need to do head gaskets any way.
What do yall think?
Motor is 2006
post #2 of 6 Old 01-17-2020, 03:00 PM
Quoted: 518 Post(s)
It might be the LPOP gears starting to rub on the front cover.
Are the flakes magnetic?
Maybe consider getting a UOA.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 6 Old 01-17-2020, 06:44 PM
ZMANN's Avatar
Quoted: 4035 Post(s)
Do not plan on a 30 over bore just to have a 30 over bore IMO
go as small as possible
STD, .010", .020", .030", .040"
6.0 flush pdf
ZMANN is offline
post #4 of 6 Old 01-20-2020, 08:36 AM
Probably your lpop, i had the same issue in my 03 6.0, ended up being scowling on my lpop , plan on getting the oem one as well as front cover kit hope this helps 🤘🏽
JRo_6.Slow is offline
post #5 of 6 Old 01-20-2020, 02:22 PM Thread Starter
Unfortunately I didn't check magnetism when the flakes were found.
I did order the UOA kit from Blackstone, but unsure how helpful it will be without the old oil (less than 100 miles on fresh oil). Is there a certain number of miles I should wait before doing the UOA?
Assuming some of the flakes have bypassed the oil filter, is the damage already done?
post #6 of 6 Old 01-22-2020, 11:19 AM
Quoted: 16 Post(s)
Pull the filter back out and run a magnet around the lower end of the housing.
bismic and [email protected] like this.
Sean
Yahiko is offline
