Cylinder #2 Contibution Code! - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-15-2019, 02:32 PM Thread Starter
Captkevin85's Avatar
Good Evening Everyone,
About a year and a half ago I pulled the motor and did some work on it. Reman ford UCF machine shop Oringed heads, arp studs, lifters, pushrods, resealed motor, stc fitting again, ford head gaskets, new cam and crank sensors, glow plugs, and a set of 8 ford reman injectors from ford. total cost was around 6k and that's with all oem parts.
The truck was running great no issue until yesterday. I was driving highway speeds for about 35 mins. I started feeling a cylinder drop out. It was intermittent and then about an hour into trip it had noticeable mis. I noticed it was blowing some black smoke as well. I also have a GH SRL+ tune which unless stomping on it is semi clean. I got to work and I pulled the codes to see cylinder #2 contribution code. Never had any codes till today.
Anyway truck cooled off overnight and when I started it to go home it sounded fine. Got on the highway seemed fine then it started acting up again. Same Code came back.
Today I pulled the air cleaner to check chafing on the harness and seemed the wires were ok. Also Checked ficm connections and they were pluuged in all the way with no damage.
I have autoenginuity scan tool but the power balance test sucks. But one by one I disabled the injectors while running and noticed when disabling #2 it wasn't changing sound. when shutting off the other ones you would hear a change in exhaust.
Today in the daytime I noticed grayish smoke at idle and driving it was the same. When Starting It will blow a decent amount then clear out. I parked it for now fearing maybe injector nozzle is cracked.
Lastly I cranked the motor at the battery and motor sounded fine. (No Skip).
I want to that the injector is bad which I'm shocked because its a ford reman. It should be under warranty still, just sucks that its cold in the northeast and have to work outside.
Any Info or opinion will help. Thanks
Captkevin85 is offline
