Firing but not staying running - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-08-2019, 09:08 AM Thread Starter
Alright need some help for a problem thatís kicking my butt. I have a 2006 6.0 that seems to want to start and fires but wonít stay running. Iím getting lots of white smoke when it attempts to fire. I though it was the glow plugs so replaced all of that. Still having the same issue. Any help would be appreciated.
Sent from my iPhone using Tapatalk
Dcrvp is offline
post #2 of 12 Old 12-08-2019, 09:11 AM Thread Starter
Only code that are showing on my sg2 are egr which is deleted and transfer case motor code.
Dcrvp is offline
post #3 of 12 Old 12-08-2019, 10:03 AM
SuperCrutyPS's Avatar
Quoted: 649 Post(s)
Garage
How much fuel in the tank?
Have you checked the fuel filter bowl to see if it's filling up.
Do you hear the fuel pump run when key on?
Just some thoughts.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is offline
post #4 of 12 Old 12-08-2019, 10:41 AM Thread Starter
Itís half a tank, and yes the fuel bowl is filling up.
Dcrvp is offline
post #5 of 12 Old 12-08-2019, 02:56 PM Thread Starter
youtube.com/watch?v=EqHxuBx-CcU
Here's a video of what my truck is doing
Dcrvp is offline
post #6 of 12 Old 12-08-2019, 03:29 PM
ChrisSki's Avatar
Quoted: 588 Post(s)
Does the white smoke smell like fuel? When you removed the glow plugs, any sign of liquid? Does the truck pass the bubble test with the fuel bowl? How about FICM voltage? Is the scrolling display just a camera effect or do you see that on the odometer?
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #7 of 12 Old 12-08-2019, 05:29 PM Thread Starter
Yes it smells like fuel, No liquid on the glow plugs, haven't tried the bubble test. Ill try that tomorrow, FICM voltage is showing 48 when the truck is key on. Its a camera effect
Dcrvp is offline
post #8 of 12 Old 12-08-2019, 05:58 PM
R&Rpowerstroke's Avatar
Quoted: 107 Post(s)
Garage
When you turn the key to on do all 8 injectors chatter? My ficm went out and still showed 48 volts on the monitor, but didn't chatter on both banks just one side.
03 250 ccsb blue spring, UCF ported and polished heads, Odawg SR3, ficm tuner, SCT x4 with custom tunes, 4" turbo back to 6" tip, Magtec diff covers, Amsoil fluids, ARP 625's, Airlift bags, Kc stage 1, Dieselsite hpop, Vision Hauler 19.5's, No Limit intake, full on board air with 8.5 gallon tank, train horns, Sinister degas, DieselSite water pump, Big Wig rear sway bar, 7.3 clutch fan, BPD adapter
Wife's new ride 2019 F450 Lariet Ultimate CCLB 4x4
R&Rpowerstroke is offline
post #9 of 12 Old 12-08-2019, 06:19 PM
Quoted: 482 Post(s)
Garage
Can't tell from the vid, but does the tach come up when cranking?
Curious if you have any fuel pressure? (I read about the bowl filling)
What are the ICP and IPR readings?
and is Sync staying on?
Disconnect the IPC sensor and try cranking
reasoning is that sensor changes from engine static, to engine running -- possibly shorting out
Oil pressure "gauge" on the dash reading when it starts?
Bubbles in the fuel rail, unless it is real bad, would only affect one bank of injectors
still worth pulling the bowl cover and checking -- use the fender jumper wire to crank the engine
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #10 of 12 Old 12-09-2019, 04:38 AM
Quoted: 467 Post(s)
The scangauge is a very poor code reader. Download ForSan to your phone or laptop and get the OBDII adapter. Read the codes then. It may point to the bad injector(s).
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
