2007 powerstroke 6.0 Intermittent power loss - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-17-2019, 06:31 PM Thread Starter
Quoted: 2 Post(s)
Exclamation 2007 powerstroke 6.0 Intermittent power loss
Hi guys, I own a 2007 f350 6.0 powerstroke, The symptom in my truck is that the power is intermittent (accelerates, loses power, accelerates, loses power, as if it had a hiccups) i take to the shop and send the codes:
P0460 Fuel Level Sensor A Circuit
P0069 MAP - Barometric Pressure Correlation
P0299 Turbo / Super Charger Underboost
P0470 Exhaust Pressure Sensor
This is my first powerstroke and I'm barely learning diesel engines.
Does anyone have experience in similar symptoms?
Thanks for your help.
Name:	Captura de pantalla 2019-10-17 a la(s) 6.18.33 PM.png
Eduardo Delesp is offline
post #2 of 2 Old 10-17-2019, 07:32 PM
Quoted: 386 Post(s)
You need a scan tool that can retrieve engine data. ForScan Lite is an app for a smartphone. BAFX makes a great OBDII adapter (WiFi for iOS and Bluetooth for Android).
When you get one, post MAP, EBP, and Baro at KOEO.
At what elevation do you live?
Also, look for leaks in the intake or exhaust.
Inspect the MAP sensor hose for leaks or restriction.
Inspect the EBP sensor and metal tube for restriction.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
