2003 Excursion 6.0 - Ford Powerstroke Diesel Forum
 6Likes
LinkBack Thread Tools
Old 10-09-2019, 05:03 AM Thread Starter
Code p132B
I an not able to relearn Vgt I have no intake leaks no exhaust leaks my fuel pressure is 55psi wot I am using fords IDS for diag I am pulling my hair out please help
Matt1128 is offline
Old 10-09-2019, 05:21 AM
Heavy_GD's Avatar
Quoted: 3136 Post(s)
Garage
Feedback Score: 4 reviews
Google:
bismic likes this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
Old 10-09-2019, 06:10 AM Thread Starter
I have replaced the turbo with a ford reman
Turbo replaced cac cooler replaced map sensor
Truck has 250 thousand on the odometer truck was running great shut truck off went in to the store came out started truck and took off no power no boost like someone shut of a light switch
Matt1128 is offline
Old 10-09-2019, 06:50 AM
Quoted: 416 Post(s)
Garage
Check the harness for damage at the turbo -- lots of heat there and the insulation gets brittle
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
Old 10-09-2019, 07:07 AM Thread Starter
My vgt is cycling and working properly performed pinpoint for map and maf all checked it fine
Matt1128 is offline
Old 10-09-2019, 08:43 AM
Quoted: 402 Post(s)
On vehicles built before Sept 29, 2003 (PCM ignores EBP sensor input and infers the value from the MAP and MAF sensors). On these vehicles, the MAF is used for fuel correction. The PCM will learn MAP and MAF and then learn the VGT action by cycling the VGT duty cycle in steps from 85% to 0%, and then back up, again in steps. It will learn the MAP and MAF action during this process. It takes 6 cycles to learn the VGT. P132b will be set if the PCM determines that there is something wrong with what it learned for MAP and MAF as it relates to VGT duty cycle.
Maybe a MAF sensor issue? Still might be a VGT actuator issue - I assume that the rebuilt turbo did NOT come w/ a new VGT actuator?
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
Old 10-09-2019, 09:07 AM
Quoted: 416 Post(s)
Garage
Should be able to force a VGT relearn on those models ..correct?
General note:
Hydro is offline
Old 10-09-2019, 09:15 AM
Quoted: 402 Post(s)
Yes. He should be able to do that.
Mark
No-start thread:
bismic is offline
Old 10-09-2019, 10:54 AM Thread Starter
Heading home to inspect map vgt and maf readings will post my results thank you guys for your inputs
Bismic you are correct no it did not come with on but one is on order
Matt1128 is offline
Old 10-09-2019, 01:53 PM Thread Starter
ok Koeo readings map v 1.32 / map psi 14.79 / Maf v 0.05 /0.00 g/s / baro v 4.60
Koer map v 1.32 / map 14.79 psi /maf 1.5v /maf30.05 g/s / baro 4.60 v
Watching pids vgtlrn No and vgtvp count stuck on 1
Matt1128 is offline
