Blown inercooler seal - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 21 Old 10-08-2019, 10:23 AM Thread Starter
Quoted: 8 Post(s)
I've recently installed another inercooler due too the previous one having the seal blown out little less than 2months later it just happened again.......
Truck info
2005 F-250 108k miles
Arp head studs
Black diamond head gaskets
Egr delete
New boots and pipes
5 inch exhaust
New injectors
New oil cooler
Sct tuner ( was on factory settings)
Sinister diesel coolant filter kit
Any ideas????? Waste gate needed?
Sharnold is offline
post #2 of 21 Old 10-08-2019, 01:27 PM
jokester00's Avatar
Quoted: 528 Post(s)
Garage
The intercooler that just failed after 2 months - was it OEM or aftermarket AND was it new or used when installed? What kind of boost pressures are you seeing? VGT%, EBP, MAP, MAF sensor data all normal while driving?
No need for a wastegate, just gotta figure out the problem...
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 21 Old 10-08-2019, 01:32 PM Thread Starter
Quoted: 8 Post(s)
18psi boost
VGT % normal
Map normal
Maf normal
Aftermarket inercooler- brand new
They are sending me a free replacement
Sharnold is offline
post #4 of 21 Old 10-08-2019, 01:35 PM
jokester00's Avatar
Quoted: 528 Post(s)
Garage
Originally Posted by Sharnold View Post
18psi boost
VGT % normal
Map normal
Maf normal
18psi is all you see at WOT? What brand aftermarket intercooler?
-jokester
Edge EAS EGT probe
post #5 of 21 Old 10-08-2019, 01:44 PM
Quoted: 509 Post(s)
-jokester
What I was thinking also. There is not enough detail to those numbers for my liking.
Heavy_GD, jokester00 and Hydro like this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #6 of 21 Old 10-08-2019, 02:02 PM Thread Starter
Quoted: 8 Post(s)
Exhaust back pressure 54.64
Vgt duty cycle 0.84
Map 13.77 psi
Baro 13.93 psi
Will only boost to 18 psi now was boosting 28 shows neg 0.75 psi at idle psi numbers only gets lower the more the seam is splitting
Brand inercooler TYC
These numbers are all at idle
First picture is the current seal second is the old inercooler both was blew out on the lower passenger side
ID:	723881   Click image for larger version
Sharnold is offline
post #7 of 21 Old 10-08-2019, 09:19 PM
Quoted: 21 Post(s)
The EBP seems very high especially for 5".
Vgt duty cycle 0.84
Map 13.77 psi
Baro 13.93 psi
6(siX)liter is offline
post #8 of 21 Old 10-09-2019, 04:14 AM Thread Starter
Quoted: 8 Post(s)
Vgt duty cycle 0.84
Map 13.77 psi
Baro 13.93 psi
Turbo cleaning time? Vgt solenoid failure?
Sharnold is offline
post #9 of 21 Old 10-09-2019, 06:58 AM
Quoted: 517 Post(s)
Garage
What are those readings engine off?
EBP sensor could be bad -- cleaned out the tube lately?
Do you hear in the exhaust the turbo change sounds just after starting the engine? -- get a helper or setup a recording, you cant run around there that quick
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #10 of 21 Old 10-09-2019, 07:40 AM
jokester00's Avatar
Quoted: 528 Post(s)
Garage
FYI - if you're reading EBP from an SCT device, they are known to read incorrectly. Need to find another scanner/monitor to use for that one. Everything else should be fine though...
-jokester
Hydro likes this.
Edge EAS EGT probe
