Oil leak - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By jokester00
post #1 of 4 Old 10-07-2019, 11:36 AM Thread Starter
Oil leak
Bought an 04 powerstroke back in June of this year. Purrs like a kitten. Have noticed in the last couple months there is a slow oil drip. Sometimes the puddle is as big as a soft ball. There have been no changes in pressure or temp and it still purrs like a kitten. We haven't been able to find where the leak is coming from. Was wondering if it could be a seal from the oil cooler. Any feed back would be helpful!! Thank all!!!
Jwayne86 is offline
post #2 of 4 Old 10-07-2019, 11:55 AM
jokester00's Avatar
Quoted: 465 Post(s)
Garage
Could be coming from literally 15-20 places. Gotta climb all over the top of the engine and give it a thorough looky-loo with a telescoping mirror and a bright light.
Is it an early or late 04 (is your ICP on the passenger valve cover or behind the turbo on the HPOP next to the IPR?)? If it's early model, the ICP sensors are prone to leaking.
-jokester
bismic likes this.
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 4 Old 10-07-2019, 02:13 PM
ChrisSki's Avatar
Quoted: 554 Post(s)
like jokester said have to trace it back to the source. If that doesn't work, you have to clean it up, let it leak and trace back to the source. There's a UV die kit.
Mine leaks a drop or two a day. I don't worry about that. A softball sized leak in a day, I would. If mine sits a month, I might get a softball sized leak, which I don't worry about.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #4 of 4 Old 10-08-2019, 04:10 AM
Quoted: 21 Post(s)
I say the same thing except I'd clean it first. Putting it on jack stands and pulling the front wheel and wheel well of the side that it leaks on will give you a good view of the engine's side.
6(siX)liter is offline
