Cruise control not working on my 2005 - Ford Powerstroke Diesel Forum
LinkBack Thread Tools
Old 09-27-2019, 10:52 AM Thread Starter
Quoted: 19 Post(s)
I switched out the brake pedal switch on the master cylinder and the rear diff ABS sensor. Still won't work. The light does not illuminate on the dash. The A/C and radio controls work on the other side of the steering wheel. What is correct way to diagnose the cause?
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow/intercooler piping, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs, 270 amp alternator with 2/0 wires.
Invasivore is offline
Old 09-27-2019, 01:11 PM
SuperCrutyPS's Avatar
Quoted: 615 Post(s)
Garage
Is there a fuse for CC?
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB
5th Wheel |
Proud US Navy Veteran | '76-'80 - Petty Officer 2nd Class (E5) - U.S.S. Point Defiance (LSD-31) - 'Gator Navy
SuperCrutyPS is offline
Old 09-27-2019, 01:27 PM
Quoted: 384 Post(s)
If the master cylinder pressure switch leaks (this is the switch that shuts off the cruise control when the brake is applies), it can cause corrosion on the wiring that shuts off the cruise control. Check that and if it looks ok, it might be the clock spring.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
Old 09-27-2019, 03:55 PM Thread Starter
Quoted: 19 Post(s)
But will a clock spring be bad, if all the other functions on the steering wheel work?
Old 09-27-2019, 04:40 PM
Quoted: 390 Post(s)
Garage
There is a resistance value sent to the controller to activate the different cruise functions
odd setup I know, but that is what it is
I would think this could be measured at the controller to verify the clock spring and switches
you could then simulate the proper resistance to activate the controller
just need to find that wiring diagram
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
Old 09-27-2019, 07:26 PM
Quoted: 390 Post(s)
Garage
Found a wiring diagram that may help --
shows the cruise switches with resistor values
trying to troubleshoot this part would rule out the switches and clock spring
General note:
Hydro is offline
Old 09-27-2019, 07:38 PM
partyman97_3's Avatar
Quoted: 894 Post(s)
Garage
I had the same problem. I replaced the switch on the master cylinder and still no cruise. Got the multi meter out and had no 12 volts at the switch. All the fuses were good. So I ran a separate wire for the 12 volts to the switch. All good now.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is online now
Old 09-27-2019, 08:00 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 601 Post(s)
Feedback Score: 11 reviews
if i am reading your post correctly, you bypassed the clock spring. replace it.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
Old 09-27-2019, 08:06 PM
Quoted: 894 Post(s)
Garage
I did replace it. thanks
Old 09-27-2019, 08:10 PM
BBBRRRRRTTTTT
Quoted: 601 Post(s)
you. are. welcome.
