03 6.0 no turbo whistle at idle - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Heavy_GD
post #1 of 8 Old 09-26-2019, 08:30 AM Thread Starter
Ccontreras0917's Avatar
I recently purchased a new truck has 3.5" straight pipe egr delete looney tune. I can't figure out why it's not whistling at idle has plenty of boost when in the throttle and plenty of power
Ccontreras0917 is offline
post #2 of 8 Old 09-26-2019, 08:32 AM
jokester00's Avatar
Quoted: 465 Post(s)
Garage
Might be the tune. Some people ask the tune writers to keep their vanes open at idle (i.e. no throttle) so they don't have the hair dryer jet sound. You could probably contact the tune writer and they can find out if that's the case.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 8 Old 09-26-2019, 08:35 AM Thread Starter
I have contacted my tune writer and he wrote me a new tune which didn't fix the issue and i also returned the truck to stock which also didn't fix it the vgt duty cycle is at 65-67% at idle while my tuner said he set it to 75%
post #4 of 8 Old 09-26-2019, 08:38 AM
jokester00's Avatar
Quoted: 465 Post(s)
Garage
Hmmmm...
Does your VGT ever hit 15% or 85% when you're driving around?
-jokester
Edge EAS EGT probe
post #5 of 8 Old 09-26-2019, 08:56 AM Thread Starter
No it does not
post #6 of 8 Old 09-26-2019, 09:21 AM
Heavy_GD's Avatar
Quoted: 3121 Post(s)
Garage
Feedback Score: 4 reviews
there is an ECU re-learn after each tune switch.
also plenty of boost and power does not mean the turbo is cycling.
jokester00 likes this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #7 of 8 Old 09-26-2019, 09:28 AM Thread Starter
I just tried unplugging the vgt solenoid and when I unplugged it there was no whistle at all and when I plugged it back in there is a slight whistle but not as loud as it should be at all especially for a 03 I'm thinking it could possibly be the ebp sensor
post #8 of 8 Old 10-05-2019, 01:48 PM
Quoted: 9 Post(s)
My stock 2003 does not whistle at idle. Didn’t know it was suppose to. Usually mine is most noticeable at about 5lbs of boost.
50dan is offline
