Sending Unit Screen Assembly Broken Off -- Trend Obvious - Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By Heavy_GD
  • 1 Post By bismic
post #1 of 8 Old 09-17-2019, 06:12 AM Thread Starter
2003 Ford F350's Avatar
Quoted: 2 Post(s)
Interesting factoid - so both of the last two Mid-Aft diesel tanks I've worked on (cleaning, water algae removal) had broken off screen assemblies. Each was broken at the same point --- the intersection where the "down pipe" meets up with the screen assembly -- essentially at the perpendicular "T" point. It's pretty obvious that the material thickness at the screen housing where it mates at the "T" needs to be "built up" / thickened -- the existing Motorcraft parts are very thin at this point.
They were both original Motorcraft parts (2003 SRW and 2007 DRW SuperDutys). The result of these failures was that the sending units couldn't pick up the last few gallons of diesel at the bottom of the tank and clearly weren't filtering garbage. The "good news" if any is that water that normally collects on the bottom of these tanks won't make it's way as readily to the HFCM. The bad news is there's probably a reasonably high likelihood many other Powerstrokes out there have broken off factory screen assemblies.
Farmer (Green Tractors), Retired USAF F-15E Driver
2003 F350 Non BulletProofed 135K, ICP Relocated w/Tractor Hose, Fittings
2007 F350
F-650, F-700 Dump Trucks
2003 Ford F350 is offline
post #2 of 8 Old 09-17-2019, 06:59 AM
Heavy_GD's Avatar
Quoted: 3116 Post(s)
Garage
Feedback Score: 4 reviews
Its a pretty known topic, most would find it by searching 1/4 tank issues via google.
I believe we should sump all things.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #3 of 8 Old 09-17-2019, 09:35 AM Thread Starter
Quoted: 2 Post(s)
Sump pumps, while technically superior, just won't work here on the farm or for 4x4s that "encounter" all sorts of things. Hanging something down in the "air stream" is asking for problems - in fact, I believe (in my case) the Motorcraft "accordian" / "bellows" fuel screen/pickups "bought the farm" "encountering" things on the farm, trail hitting the outside of the plastic tank then "overcompressing" those "bellows" on the bottom of the sending unit. I've thought about adding "lift" to these vehicles but have owned many lifted vehicles that just handled badly post the mods.
2007 F350
post #4 of 8 Old 09-17-2019, 10:04 AM
Quoted: 351 Post(s)
Garage
Maybe you just need a skid plate :thumbsup:
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #5 of 8 Old 09-17-2019, 11:15 AM
Heavy_GD's Avatar
Garage
I hear ya, but I dont.
Patriot and Hydro like this.
GD
Heavy_GD is offline
post #6 of 8 Old 09-17-2019, 12:51 PM
Quoted: 314 Post(s)
I have known of a LOT of sumps put in on our 6.0's. I have not heard of one suffering failure from impact damage. Maybe it has happened, just that I haven't heard of it. Same for the oil drain fumoto valves.
Patriot likes this.
bismic is offline
post #7 of 8 Old 09-17-2019, 09:04 PM
'consent of the governed'
Patriot's Avatar
Quoted: 2182 Post(s)
Garage
What he said.
Patriot is offline
post #8 of 8 Old 09-18-2019, 04:58 AM
Heavy_GD's Avatar
Garage
Everyone is worried, except for the people running them.
GD
Heavy_GD is offline
