05 6.0 no start - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By bismic
  • 1 Post By bismic
post #1 of 10 Old 09-13-2019, 08:00 AM Thread Starter
LUGGNUTT's Avatar
05 6.0 no start
234k+ mi, EGR delete done at dealership when bought new, not studded.
Truck had started to become a long crank slowly getting worse for about 2 weeks. Then I didn’t start anymore.
I have (after no start) replaced
Oil/filter, fuel filters and a blue spring kit, stand pipes/dummy plugs, STC fitting,ICP, IPR checked cleaned( no screen damage or debris).
Any advice on my next step would be welcomeed
ID:	723119   Click image for larger version
ID:	723121   Click image for larger version
LUGGNUTT is offline
post #2 of 10 Old 09-13-2019, 08:03 AM Thread Starter
LUGGNUTT's Avatar
Info sheets are from my DashBoss.
LUGGNUTT is offline
post #3 of 10 Old 09-13-2019, 01:34 PM
Quoted: 324 Post(s)
Your cranking speed is too low and so are your vehicle volts.
Charge and individually load test the batteries.
jokester00 likes this.
bismic is offline
post #4 of 10 Old 09-13-2019, 03:51 PM Thread Starter
LUGGNUTT's Avatar
Thank you for the reply. The batteries where done just as you suggested. I had been doing cranking intervals to get early readings then moved to checking connections. I failed to record the data till I was about done.
The Volts never showed on the ficm main above 10.5,
I did a pin test KOEO prior to this and had 48v.
Are the batteries really going to cause all the codes?
LUGGNUTT is offline
post #5 of 10 Old 09-13-2019, 05:01 PM
Quoted: 324 Post(s)
They could. You also will never get a start if the cranking rpms are below 150. If it isn't your batteries, then it is likely to be your starter. Load testing batteries is free .........
A simple voltage check means nothing. A battery can read 13 volts and then drop to zero w/ a load.
bismic is offline
post #6 of 10 Old 09-13-2019, 07:12 PM
Quoted: 358 Post(s)
Garage
Battery cable connections(check both ends) -- one or both batteries bad
Quick and dirty load test can be done by removing the driver side battery -- crank with head lights on and observe the voltage(brightness of the lights is also an indicator)
Swap in the removed battery into the passenger side and re-test
If the battery/starter/cables are fine, the engine will crank with only one battery
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #7 of 10 Old 09-14-2019, 06:41 AM Thread Starter
LUGGNUTT's Avatar
Thanks guys. The batteries were fully charged and a load test was done previously before the scans.
My wording was possibly not apparent enough in my 3rd post. Apologies for that.
I have a Snap on MT3750 AVP that I did the load test on. Volts never dropped below a 9.6 on a 15 second load test. 650 amps showing on both 810 cca batteries.
LUGGNUTT is offline
post #8 of 10 Old 09-14-2019, 08:19 AM
Quoted: 324 Post(s)
Battery voltage below 9.5V will cause delayed/hard starts. You are pretty close to that and maybe you are dropping below that but your update frequency isn't showing it.
FICM Vehicle Power (Volts) (Should be 12+ Volts, should never drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03
As posted above, if you aren't getting 150 rpm cranking, it won't start. That is the focus are IMO.
Hydro likes this.
bismic is offline
post #9 of 10 Old 09-14-2019, 09:32 AM Thread Starter
LUGGNUTT's Avatar
I Appreciate your input, it was getting above 150 rpm when I started checking things out. As mentioned I didn’t record any info until I had been trying different things for about an hour(ie watching the scanner, and having someone else crank it over while I was checking connections.)
So the batteries were low when I remembered to record the data.
I have a different (known working) FICM on its way.
I will have it Tuesday.
Again thank you for your help.
LUGGNUTT is offline
post #10 of 10 Old 09-14-2019, 09:39 AM
Quoted: 324 Post(s)
Good deal. Please keep us informed!
bismic is offline
