2004 F350 6.0 Turn signal issue - Ford Powerstroke Diesel Forum
post #1 of 1 Old 09-12-2019, 05:08 PM Thread Starter
So i have no turn signals no noise when in use nothing showing on guage or outside my hazzards do work.So i checked fuse 18 in the kick panel it was good i replaced the relay underneath the dashboard and i replaced the turn signal switch itself not sure where to go afyer this only thing i could think of is if there is a seperate relay for the hazzard/flasher from the turn signal because in the relay box under the dash there was a spot for 2 relays but only one was in there the one closer to the inside of the cab the one towards the firewall does not use the same relay its a bit bigger. Any help would be great at this point im stuck
dheroux1 is offline
