someone keep me from pushing my 6.0 off a cliff - Ford Powerstroke Diesel Forum
 4Likes
  • 2 Post By bismic
  • 2 Post By bismic
post #1 of 10 Old 09-05-2019, 04:25 PM Thread Starter
k so here goes...2004 6.0, had a hot side intercooler blow off. figured it was due to the oil in the pipe, found out that was normal. so i changed boots and clamps on my hot side. didnt fix the problem. changed the MAP sensor and the hose, still same thing. used ford boots and clamps the first time (mistake) so i replaced them with mishimoto clamps and hoses. still same thing. got a tip that the butterfly valve on the intake sometimes will not operate properly and this could lead to pressure buildup. removed that, changed the original ford cac pipe to metal with new hoses and clamps, everything torqued down properly. ran it this last time, and it felt like i only got about halfway into the powerband, and that was all i was going to get, watching boost gauge, 19psi. then the hot pipe blew off again. any ideas on what im missing? is it possible that the manifold is that coked up and not running air thru? id appreciate any help anyone can give, bout at wits end with this damn thing.
ruste415 is offline
post #2 of 10 Old 09-05-2019, 04:49 PM
Quoted: 517 Post(s)
Garage
Wouldn't hurt to stick on of those snake cams in the intake and take a look
Use denatured alcohol to clean the inside of the hose and outside of the turbo fitting -- then use VO5 hair spray to give some stickum to the hose joint -- be sure the clamp is square to the hose and just behind the "bump" on the fitting
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 10 Old 09-05-2019, 05:39 PM Thread Starter
um not good at this posting thing, tried, dont know if the response ever went thru, apparently this site thinks im a robot. anyway, tried hairspray trick, clamps are square to the pipe and behind the lip on the pipe. the last time i ran it it felt like it was starving for air going uphill, ever hear of an intercooler getting gummed up? really just trying to figure out which part to take off next
ruste415 is offline
post #4 of 10 Old 09-05-2019, 06:30 PM
ChrisSki's Avatar
Quoted: 594 Post(s)
As far as manifold getting coked up, with an EGR it will leave carbon deposits, whether it interferes like you think I don't know. A manifold is time consuming to get to. I like the idea of snake cam down the intercooler. You could always remove it. Doesn't look terrible to remove if you really wanted to take a look:
IMO, the boots blowing off are a problem with the boots. I feel the other stuff you're thinking would make higher pressure than 19 PSI. If you used an old fashioned hairspray like V05 or Aqua Net extra hold, let it dry overnight, after changing clamps and boots, then I can only recommend calling whoever you got the boots from for options. I have a couple of metal O-RIngs that I could add that would prevent my pipes from slipping off if it happens again. They go between the boot and the pipe.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #5 of 10 Old 09-05-2019, 07:26 PM Thread Starter
ive changed the boots twice already aquanet both times, new clamps both times. from the way the engine sounds, im thinking somethings backed up. hell im no expert, but every time i get up over 15psi, the sound of the motor changes, like its struggling to breathe. what i was thinking is that the MAP sensor is getting incorrect info causing the turbo to work overtime to try to dump more air into the motor. just dont know what the cause is. figured someone would have had that problem. i hear you about the boots, but ive tried two different types, and although im inexperienced in diesels, i am familiar with turning wrenches. pretty sure ive ruled those out. just wasnt sure which direction to go. feel like it would be hard to clog up an intercooler tho. but like i said, im no expert. was hoping someone would have seen or heard of someone dealing with this in the past.
ruste415 is offline
post #6 of 10 Old 09-05-2019, 07:31 PM
Quoted: 509 Post(s)
You need to scan for codes w/ a quality code reader.
Also, you need to tell us what the MAP and Baro readings are w/ KOEO.
Patriot and jokester00 like this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #7 of 10 Old 09-06-2019, 05:28 AM
Quoted: 517 Post(s)
Garage
Tee in a gauge on the MAP line and lets see what your actual pressure is -- the system should hold 30psi easily
General note:
Hydro is offline
post #8 of 10 Old 09-06-2019, 03:47 PM Thread Starter
was watching the pressure from my scangauge 2 as i was running, thats where i was getting my info from. didnt pull any codes from that, didnt hook up my good obd 2 reader tho, tore damn thing down last nite, so its gonna be a day or two before its back together, but when ive got it back up and running, ill take a look with the good scanner. the readings i was getting for map was 0.1, and it seems like it was moving up properly. like i was saying, i got about halfway into the throttle, and it sounded like it started to bog down, and then the boot blew off, was watching scangauge and it was at 19psi, which if i understand correctly is directly from map sensor, correct? which i did change, and really hadnt seen any difference before and after changing the map sensor and hose. got about the same readings both ways, and am consistently blowing the hose off at about 19psi. thanks all of you for your help. i do appreciate it. cant afford a new truck or to take this in to a mechanic, and i value you guys effort for someone you dont know.
ruste415 is offline
post #9 of 10 Old 09-06-2019, 04:50 PM
Quoted: 509 Post(s)
If the units are in psi, the LOWEST MAP reading would be atmospheric pressure (14.7 psi at sea level).
That is why we need to see MAP, Baro, and EBP (if you have the late 04 engine) at KOEO.
Oh btw - the scangauge is a terrible code reader.
jokester00 and Hydro like this.
Mark
No-start thread:
bismic is offline
post #10 of 10 Old 09-06-2019, 06:55 PM
Quoted: 517 Post(s)
Garage
Barometric usually reads out in inches of mercury (29.9 Hg) = atmospheric pressure 14.7 -- depending on your altitude
The Baro sensor is inside the cab near the steering column
As @bismic mentioned, all three should read the same or nearly
Use Forscan(windows version) or Torque Pro(android)
General note:
Hydro is offline
