Bunch of codes at once - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-25-2019, 12:51 PM Thread Starter
2003 6.0l F250. Starts and runs fine. Hooked up my scanner and had many codes. Scanner was not able to read the all the functions of the engine such as oil temp, egr, icp. Could only read engine rpms and air temp. Codes 1,2,6,7 cylinder contribution. P132B P1378 P2614 P2617
May I add the 4x4 control module is bad in truck and is being replaced which is also affecting my 4x4 switch that is not working.
Hunter_707 is offline
post #2 of 6 Old 08-25-2019, 01:21 PM
djmaguire's Avatar
Quoted: 1589 Post(s)
Garage
Are you sure that the contribution codes aren't for 1, 4, 6, and 7? I say this because - with most of your cylinder list and the 14/17, I'd start with checking your FICM connectors.
In fact, I'd still start with your FICM connectors.
Please update on the contribution codes. You might also try pushing on the injector harness with a stick or a dry gloved hand and seeing if anything changes.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #3 of 6 Old 08-25-2019, 01:37 PM Thread Starter
Cylinder 1,2,6,7
I do have #4 glow plug code. Engine starts and runs fine but I am not able to access the data on my scanner that I should be able to see. I’m not home right now to inspect wiring but will update when I have the chance
Please see attached Photos!
ID:	722231   Click image for larger version
ID:	722233   Click image for larger version
post #4 of 6 Old 08-29-2019, 09:37 AM Thread Starter
Update: pushed on the ficm connections and even tried pushing on the injector harness with an old cleaning rod and same codes pop back up. I cleared the codes and they return quickly after start up
post #5 of 6 Old 08-29-2019, 08:06 PM
djmaguire's Avatar
Garage
...but the truck runs fine, yes?
2004 F550 CC Lariat
post #6 of 6 Old 08-29-2019, 08:56 PM Thread Starter
Truck starts and runs fine to my knowledge. First 6.0 I’ve owned and purchased last week. No smoke out of exhaust, no rpm fluctuations at idle or cold start. All these codes and no symptoms has me scratching my head. Still do not know why my scanner can not access more engine data
