6.0 powerstroke low power - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-18-2019, 06:11 PM Thread Starter
i have a low power issue with my 05 6.0 powerstroke. takes a few seconds to start going. once it hits maybe 10psi of boost, it takes off. feels like a turbo lag, but ive ruled that out. new map sensor with hose, new ebp sensor with line, new turbo, vgt solenoid tested, working, no boost leaks. gets up to 25psi of boost WOT. ive noticed high fuel pressure. around 95-100psi. could this cause such a big power loss? truck is studded, deleted and tuned.
6.0Sal is offline
post #2 of 5 Old 08-18-2019, 07:02 PM
BTL
BTL's Avatar
Quoted: 223 Post(s)
You are doing your injectors no favors anytime FP is above 80psi. Something is amiss.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4” SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8” draw tube
BTL is offline
post #3 of 5 Old 08-19-2019, 06:11 PM Thread Starter
i thought so. would this do damage to the hpop?
6.0Sal is offline
post #4 of 5 Old 08-19-2019, 09:31 PM
repalmer's Avatar
Quoted: 629 Post(s)
Shouldn't have any effect on the hpop. It's psi will go up to 4000 psi. The fuel psi is coming from your pump and not being regulated by your regulator, i.e. the blue spring mod
repalmer is offline
post #5 of 5 Old 08-20-2019, 05:33 PM Thread Starter
just cleared the return line and i have the blue spring upgrade. now at 85psi. lol this sucks. new fuel pump too. i also took off the return line at the regulator and ran my own. still 85psi
6.0Sal is offline
