P0275 new injectors,ficm,wiring harness - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-18-2019, 11:43 AM Thread Starter
I hate to start a new thread as the p0275 topic is everwhere but I cant find a good answer. I have an 05' with 138k miles. I replaced the ficm with the 58v from sinister diesel. I have a new injector wiring harness. And I replaced all 8 injectors with Warren Deisel's remams with the upgraded spool valves. The new injectos have less than 300 miles on them and the truck was running better than ever. But yesterday I got the p0275 code with a rough idle. If I shut it off and restart it it idles right and the code goes away until I give it throttle. Once i get the RPMs up it runs fine however I get the motor vibration around 1200 RPMs telling me the injector is missing. I find it very unlikely that the injector is bad. Isvit possible the injector is sticking because it hasnt been broken in yet? Any help would be greatly appreciated as im towing 14k+ in two weeks and have very limited time to fix this.
05_6.0_powerstroke1 is offline
post #2 of 6 Old 08-18-2019, 06:25 PM
Quoted: 686 Post(s)
Does it smoke when the miss occurs?
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #3 of 6 Old 08-18-2019, 11:24 PM
repalmer's Avatar
Quoted: 563 Post(s)
New doesn't always equal good. Could've had some crap from fuel get stuck in it, or...
repalmer is offline
post #4 of 6 Old 08-20-2019, 01:29 PM Thread Starter
It doesnt smoke
It also sits most of the time as well. I put some stanadyne additives in it and the code went away but i was also only able to drive it for about 20 minutes. I intend to drive it more this weekend hopefully it doesnt come back.
post #5 of 6 Old 08-20-2019, 02:00 PM
ZMANN's Avatar
Quoted: 3899 Post(s)
you don't " break in" injectors I would move it to another location if you really want to rule it out
but i am betting it is the injector if you ruled out wiring and have a new FICM
6.0 flush pdf
ZMANN is online now
post #6 of 6 Old 09-10-2019, 06:08 AM Thread Starter
Sorry I've not been back for a bit. But after driving it a couple hundred miles its running better than ever with no codes. It must have been fuel or something. My alternator connector decided to fail though so now I get to chase it ha ha ha
