What's loose under my cab? - Ford Powerstroke Diesel Forum
 6Likes
  • 1 Post By Master_Chase
  • 1 Post By Johnny McG
  • 1 Post By voodooridr
  • 2 Post By Master_Chase
  • 1 Post By Gachong
post #1 of 10 Old 08-16-2019, 11:04 AM Thread Starter
Hello all,
I have tried to search the forum for my problem and have come up short. So here is my issue; when I am at a complete stop and begin to step on the accelerator, it feels like the engine mounts are loose since I feel movement in my truck like the engine moved. Also when I am going to a stop, I feel it again when I come to a complete stop. I am not feeling excess vibration like you would think is the motor mounts were bad or loose. Any thoughts on what that may be? Thanks in advance. BTW, 2007 F350 XLT Crew Cab Long bed 4x4
Gachong is offline
post #2 of 10 Old 08-16-2019, 12:05 PM
Master_Chase's Avatar
Quoted: 517 Post(s)
Have you checked the body mounts IIRC the 05+ crumble apart
BTL likes this.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #3 of 10 Old 08-16-2019, 12:10 PM Thread Starter
No I did not. I will check on those. Thank you master_chase
Gachong is offline
post #4 of 10 Old 08-16-2019, 11:10 PM
Quoted: 3 Post(s)
Could also be your slip yoke if you have a two piece drive shaft. If it is you will need to drop the shaft and lube the slip yoke and put it back together.
Sent from my SM-N960U using Tapatalk
jokester00 likes this.
Johnny McG is offline
post #5 of 10 Old 08-17-2019, 06:02 AM Thread Starter
[QUOTE=Johnny McG;16318777]Could also be your slip yoke if you have a two piece drive shaft. If it is you will need to drop the shaft and lube the slip yoke and put it back together.
That sounds like that’s what that could be. Thanks!
Gachong is offline
post #6 of 10 Old 08-17-2019, 07:00 PM
repalmer's Avatar
Quoted: 560 Post(s)
You won't get vibration from motor mounts going out, or loose. Have someone goose the throttle, that you trust, while you're looking at the engine, in Park, Drive, and Reverse. Holding the brake obviously. That'll tell you if the mounts are bad. Do the same for the trans mount.
Don't get run over!!!
repalmer is offline
The Following 2 Users Say Thank You to repalmer For This Useful Post:
Gachong (08-20-2019)
post #7 of 10 Old 08-18-2019, 06:58 AM
voodooridr's Avatar
Quoted: 955 Post(s)
Advice to live by
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #8 of 10 Old 08-18-2019, 11:54 AM
Quoted: 517 Post(s)
Everytime I have to hold the brake and give the engine power while looking for a problem I put it in R so if something fails you don't run over your buddy.
jokester00 and Gachong like this.
post #9 of 10 Old 08-18-2019, 12:31 PM
repalmer's Avatar
Quoted: 560 Post(s)
Advice to live by
Figuratively and literally
repalmer is offline
post #10 of 10 Old 09-06-2019, 08:43 AM Thread Starter
Hello all,
So it took me a minute but when I found the time to take a look and after numerous researching I did look at the slip yoke. After removing and applying fresh grease...problem solved!! Thank you to all who game me help and it suggestions. Thanks!
Gachong is offline
