05 6.0 oil gauge drops when tow haul is pressed - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By SCUFFY828
post #1 of 8 Old 06-20-2019, 09:11 AM Thread Starter
Going to be looking into an issue on my boss’s 6.0 for him. He just had the hpop replaced about 100 miles ago and now when we presses tow haul the oil pressure gauge drops and truck starts to buck. Haven’t looked at it yet so this could be in actuate information but looking to see if this has happened to anyone and if so where to begin looking. Possibly a wire harness didn’t he plugged back in? He stated it’s the top right gauge that drops out and believes it’s oil pressure. I have an 04 and believe my top right is tranny temp not sure about the 05.
denis_meyer is offline
post #2 of 8 Old 06-20-2019, 09:56 AM
ZMANN's Avatar
Quoted: 3884 Post(s)
top right is Trans temp
6.0 flush pdf
ZMANN is offline
post #3 of 8 Old 06-20-2019, 11:25 AM Thread Starter
Thanks for the pic I’m at work so couldn’t call look at my truck to verify. Any idea why tow haul would drop the tranny’s temp out and make the truck start running weird?
post #4 of 8 Old 06-20-2019, 12:31 PM
ZMANN's Avatar
I would start with the connectors it seems like tow haul must be making a bad connection worse ?
6.0 flush pdf
ZMANN is offline
post #5 of 8 Old 06-20-2019, 12:56 PM
Quoted: 3 Post(s)
The top right on the 2005 is Tranny Temp. When entering the Tow/Haul mode it changes the way the tranny operates, shifts etc. Pressing it should have no effect on the tranny temp gauge or start running weird.
Possibly pointing to a tranny issue, these transmissions have a lot of solenoids?
nawtbird1 is offline
post #6 of 8 Old 06-20-2019, 04:22 PM Thread Starter
Thanks for the reply guys I’m gonna have to snag the truck from him and drive it like stole it to see what it’s actually doing. As of right now I gotta get my hpop installed so I can tow my boat out and catch some halibut.
post #7 of 8 Old 06-20-2019, 04:45 PM
djmaguire's Avatar
Quoted: 1581 Post(s)
Garage
In case you need it, here is a fairly good trans document. I'd be sdtarting by looking at the connector and associated wiring for the connector shown on page 15.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #8 of 8 Old 06-21-2019, 05:42 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 26 Post(s)
sounds like trans temp sensor has gone bad ,which is not that uncommon , trans goes into default and will shift different
djmaguire likes this.
ITS STOCK
SCUFFY828 is offline
