2003 6.0l regen frequency. - Page 2 - Ford Powerstroke Diesel Forum
 24Likes
post #11 of 17 Old 05-07-2019, 06:16 PM
Quoted: 774 Post(s)
REGEN is the DPF Regeneration cycle where it burns particulate out of the DPF on 20808 6.4L- 2019 6.7L trucks.
Are you talking the VGT relearn where its pegged at 15 or 85%.... it took me a few miles for the truck to run like dog **** after i did mine and then was fine.
Got Dirt? likes this.
2007 F250 Lariat Outlaw
174k
Stock Motor
5" MBRP Catback
Boudah is offline
post #12 of 17 Old 05-07-2019, 06:18 PM
Quoted: 264 Post(s)
Garage
Yeah nothing to regen on the older trucks -- the "newer" EPA infested trucks have a Diesel Particulate Filter to catch the soot in the exhaust that needs to be burned out periodically
The VGT cycling could be from a later tune in the PCM -- that is used to keep the vanes from sticking -- this cycling only happens at idle tho after the truck has idled for a while.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #13 of 17 Old 05-07-2019, 06:20 PM Thread Starter
Quoted: 7 Post(s)
Yes, vgt relearn. I cleared my p132b code I had yesterday and let it idle for 5 -7min. I could see on my edge monitor it was running through the cycle. I didnt watch it the whole time. When I checked back it was steady at about 67%. I shut the truck off and then drove it to work and back this morning. It ran fine but sitting at a light, I noticed it trying to relearn again. So maybe it never finished?
Tathag is offline
post #14 of 17 Old 05-07-2019, 06:23 PM Thread Starter
Quoted: 7 Post(s)
How often should I see it doing this? Seems pretty frequent to me. And does that mean the 150-200mile interval is also not meant for the 6.0?
Tathag is offline
post #15 of 17 Old 05-07-2019, 06:24 PM
Quoted: 774 Post(s)
umm... i would just drive it and pack on the miles to see where you are in say a tank of diesel. It took me a good bit of driving to "be fine" after i pulled the valve covers off for dummy plugs etc. if u saw 67% then it kicked back.... make sure your connections are good and if so... let it fly but keep an eye on it.
I dont have exact numbers for you, just my few experiences with doing it.
200 mile? isnt that for the REGENs for the DPF? i dont own one so im not exact on that. if so then no not for our trucks. Thats why everyone is scratching their heads?
174k
Stock Motor
5" MBRP Catback
Boudah is offline
post #16 of 17 Old 05-07-2019, 06:28 PM
Got Dirt?'s Avatar
Quoted: 163 Post(s)
Garage
Originally Posted by Tathag View Post
The only thing I can think is maybe I didnt complete the cycle right. Like it runs the cycle 6 times, then holds steady. I didnt drive it until the following morning. Should that have been done right after?
Found this procedure - maybe it will help (I'm no expert - YMMV)
VGT learn procedure
1. Drive the truck until the engine and transmission have reached normal operating temperature.
(The VGT learn procedure requires that the oil and coolant temperatures be at normal operating temperature)
2. Flash truck back to stock (Only need to do this if running a tuner or module)
3. Turn on the headlights
4. Disconnect both batteries
5. Short out + to - battery cables to each other (Make sure both batteries are disconnected before doing this).
6. Let truck sit like this for 10-minutes
7. Turn off the headlights.
8. Re-connect batteries
9. Cycle the key to the run position twice. Pause in the “ON” position each time until the wait to start lamp goes out (minimum 5-seconds) and pause in the “OFF” position each time for 10-seconds to be sure the PCM has "gone to sleep".
10. Start the truck and let it idle for a minimum of 5-minutes at normal operating temperature. This allows the PCM to learn the EGR valve closed position value. Also you will likely hear the turbo pitch change several times during this period as the PCM learns the necessary duty cycles for accurate VGT control.
11. Complete the road test Drive Cycle:
15 miles of mixed driving (*should* be enough in most cases) to allow the PCM to "re-learn" its adaptive strategy.
Note: Anytime the batteries are disconnected, the PCM will throw the P1000 code until the “Drive Cycle” is completed.
As for the Tow/Haul mode, the transmission must re-learn your driving style and loads hauled again as this was cleared when the truck was re-flashed.
White_Buffalo7.3 likes this.
"Life is a Garden - Dig It!!!" ~ Joe Dirt
"Rub Some Dirt On It!!!"
"God Made Dirt, Dirt Don't Hurt!!!"
2006 Super Duty F-250 Lariat CCSB: Edge CTS Insight - BPD FICM - Sinister Diesel Coolant Filter - ProComp 20" wheels - Toyo M/T 35's - ReadyLift w/ Bilstein 5100's - 4" MagnaFlow Exhaust
Got Dirt? is offline
post #17 of 17 Old 05-08-2019, 07:32 AM
djmaguire's Avatar
Quoted: 1561 Post(s)
Garage
I've never heard my turbo sweep. Ever. ...but I have a late '04. The '03s and early '04s sweep on startup.
The 150-200 mile interval thing that you read was likely refering to regen cycles on a 6.4. Hard to say where the internet took you.
If your issue is that you are watching the VGT% and it is swinging between 15-85%, that's what is does by design. You do have a P132b, though.
P132B can be set by 3 methods (from DTL):
  1. MAP (boost) levels. (P132B_STK)
  2. Continuous boost monitor checks boost vs. VGT_DC. (P132B_CM)
  3. Excessive number of learn cycles (P132B_VAR)
You are probably getting yours from #3.
The DTL doc says you need to perform pinpoint test KA. I'll attach that. I'll also attach the DTL doc describing the turbo and VGT, a separate turbo description document, and a NAPA turbo diagnostic guide that's quite nice.
File Type: pdf Ford DTL - 6L Inferred EBP for 2003 and early 2004 P132b.pdf (204.3 KB, 6 views)
File Type: pdf Ford DTL - 6L Air Management System Diagnosis - Turbo subsystem.pdf (739.8 KB, 8 views)
File Type: pdf NAPA 6L POWERSTROKE VGT TURBO TESTING.pdf (1.87 MB, 12 views)
File Type: pdf Pinpoint Test KA - Turbo Charger System Performance.pdf (84.1 KB, 9 views)
File Type: pdf Tech Turbo Guide for the 6.0L Power Stroke Engine.pdf (917.0 KB, 8 views)
iHenry and Got Dirt? like this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLink™ LX, Autometer EGT
djmaguire is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
2003 6.0l long crank hard start Tfitz Diesel Diagnostics 0 09-03-2018 05:51 PM
Regen frequency question deanrd General 6.7 Discussion (2017-2019) 8 07-22-2018 04:03 PM
2003 f250 6.0L Runs Rough on First Start Up FordRavensFan6.0 6.0L Problems Forum 40 06-05-2017 01:43 PM
Thinking of buying 2003 PSD 6.0L Kappa Sig General Diesel Discussion 28 12-27-2006 11:15 AM
