High pitched whine/whistle on deceleration - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-18-2019, 06:58 PM Thread Starter
What's going on guys little background on the truck its an 05 with an 06 motor and an 03 turbo, been studded has the egr deleted and Vivan's looney wild studded tune. About 6 months back I replaced the y pipe on the truck, had a bit of whistle from exhaust that went away after tightening the manifold to y-pipe bolts, then about a month back I start to hear a very similar noise, but i can't seem to find the source. There's no soot around any of the exhaust connections, I get full 31psi at WOT and I've done a fair bit of looking them over so I can assume my intake piping and connections aren't blown out. The problem is most prevalent on deceleration and actually changes with RPM but can slightly be heard while cruising, never at idle. What is the most likely cause? I've heard everything from my degas cap to headgaskets being blown to holes in the intercooler.
I got a video of it tonight, please ignore me and my friend in the video, the best example of the noise is at the end of the video from 3:05 to 3:25.
Thanks a lot and I really appreciate any help anybody has, I'll keep this thread open on my laptop if anyone has any questions about the truck or any specifics.
popsntrucks is offline
post #2 of 4 Old 04-19-2019, 07:01 AM
Heavy_GD's Avatar
Quoted: 3099 Post(s)
Garage
Feedback Score: 4 reviews
I know you just tightened it, but it sounds like a blown up pipe.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #3 of 4 Old 04-19-2019, 10:13 AM Thread Starter
Any way other than a pressurized smoke test to see where the leak would be coming from if it is a blown up-pipe?
Also my bad forgot to link in the video
youtube .com /watch?v=e8y5RDyPSJA
post #4 of 4 Old 04-19-2019, 10:31 AM
Heavy_GD's Avatar
Garage
GD
Heavy_GD is offline
Tags
6.0 , deceleration , whine
Similar Threads
Thread Thread Starter Forum Replies Last Post
2012 6.7L Low Boost/power during high temp/humidity Murry 6.7 Motor Problems (2011-2016) 9 08-04-2019 05:56 PM
ICP Jumping and Surging White_Buffalo7.3 99-03 7.3L Powerstroke Problems 11 03-15-2019 06:16 AM
High pitched whistle dwiser3 6.0 Motor problems 6 10-27-2016 12:02 PM
Trouble with PSD dtc # 1316 bubba 1541 99-03 7.3L Powerstroke Problems 23 09-09-2009 06:23 AM
