6.0 Dies on the Road but starts right back up - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Jstahley
post #1 of 10 Old 04-16-2019, 03:59 PM Thread Starter
I have a late 04 6.0 that has a bad habit of dying while driving. Sometimes it surges but other times it just shuts off like the key was turned off. I have replaced all kinds of parts and am at a lost. Been doing this for about 5 months now so some help would be really appreciated. The truck does have an EGR delete so that is not a problem. When it does die I can put it in neutral and crank it and it will start before I come to a stop.
Parts replaced:
- ICP
- IPR
- HPOP
- FICM
- FICM Harness
Codes: the codes DO NOT appear every time it dies
- P0603 - KAM
One time these codes came up
- Glow plug 1,3,5,7 open circuit.
Notes: I did bring it to a shop where they swapped a whole bank of injectors and no difference (they gave up and didn't charge me). Also sometimes it runs fine. before it started acting up today it was driven to town 15 minutes then to multiple stores then it sat for hours and almost made it back home after work. IT STARTS EVERY TIME
This is my first post so I apologize if it is in the wrong place or if there is already a thread similar to this.
grifflanedorr is offline
post #2 of 10 Old 04-16-2019, 10:28 PM
Quoted: 9 Post(s)
Where did your ficm come from?
Sent from my SM-T810 using Tapatalk
GaterJ is offline
post #3 of 10 Old 04-17-2019, 03:50 PM Thread Starter
It's a Ford FICM
post #4 of 10 Old 04-17-2019, 04:27 PM
ChrisSki's Avatar
Quoted: 506 Post(s)
The 1357 is the passenger side, so I'd check wiring there for fraying and other signs of damage. That is solely based off the glow plug code. I also recommend downloading the 6.0 good reading n my signature block and it has some wiring diagrams, block diagrams, and other good info. If you can't read my signature block because not enough posts, google 6.0 bible pdf. I'd also trace the CAM sensor as best you can. A bad cam sensor will make it die, but not a good idea to throw that part at it.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #5 of 10 Old 04-17-2019, 05:48 PM Thread Starter
I'm going to check the CAM tomorrow. I've also read to check the crank position sensor pigtail for chafing so I'll do that also.
post #6 of 10 Old 04-20-2019, 12:07 PM
Jstahley's Avatar
Quoted: 26 Post(s)
I 2nd checking for chafing wires. Sounds like something shorting out. Have you tried wiggling wires to try n get it to stall out. Are the ficm plugs seated tight with the clips
djmaguire likes this.
Jstahley is offline
post #7 of 10 Old 04-20-2019, 07:35 PM
djmaguire's Avatar
Quoted: 1553 Post(s)
Garage
- P0603 - KAM
Originally Posted by ChrisSki View Post
... I'd also trace the CAM sensor as best you can. ...
I'm going to check the CAM tomorrow. ...
KAM is not CAM. Leave the sensor alone.
It's more likely chafing, a connector, or the PCM.
___________
Edited to add...
To help things along - if I had an intermittent KAM code and had not run knowingly run my battery down, I'd first check my battery connections. If good, I'd then monitor system voltage while driving to see if I had a spurious voltage drops due to a loose plate.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #8 of 10 Old 04-21-2019, 01:38 AM
repalmer's Avatar
Quoted: 407 Post(s)
Sorry guys, this isn't pertinent to the thread.
The two dollar bills in the pic have the same serial number. That means one of them is counterfeit. Does that mean there's only 1 sex?
repalmer is offline
post #9 of 10 Old 04-26-2019, 09:00 PM
Quoted: 9 Post(s)
Just checking to see who alls paying attention
GaterJ is offline
post #10 of 10 Old 04-26-2019, 10:20 PM
repalmer's Avatar
Quoted: 407 Post(s)
Not the OP
repalmer is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Starts runs 45 seconds dies Stevejudy 6.0 Motor problems 4 05-21-2018 08:43 AM
6.4 cranks and starts then dies duallyboi73 General 6.4L Discussion 2 05-11-2018 02:48 PM
6.0 Dies and wont start back up hidescraper 6.0 Motor problems 45 05-30-2017 05:37 AM
Starts right up then dies Deer Creek 6.0 Motor problems 0 10-20-2016 08:47 AM
Engine quit during coolant flush flush. Now only runs for a few seconds and dies jjplumley 99-03 7.3 Motor Problems 11 10-17-2016 03:12 PM
