6.0 is down and need some advice! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-15-2019, 06:05 AM Thread Starter
Jakob Wilson's Avatar
Okay so to start of my 2003 f250 6.0 has 305k stock head bolts, EGR delete, and the rest is completely stock. I was pulling a 8000lb skid steer up the highway about 70 when I heard a loud pop followed by a cloud of white smoke and the engine shut off on me. I got it to the side of the road when I got out I had lost atleast 1 gal of oil on the ground. There is oil all over the driver side engine and on the fire wall. But none in the engine valley or on the passenger side.
I am just trying to figure out some suggestions on what it could be.
Jakob Wilson is offline
post #2 of 7 Old 04-15-2019, 06:27 AM Thread Starter
6.0 is down need some advice!
Also I forgot to add the oil isn’t milky and I had a fresh oil change about 200miles ago
post #3 of 7 Old 04-15-2019, 07:33 AM
PowerPunisher's Avatar
It sounds like when I blew my intercooler charge hose and the egr system fully crapped out on me. I was pulling 10k at 65 mph when I heard a loud pop! It was the cold side intercooler charge hose that had a hole blown in it from the turbo pressure while towing. The plastic charge hose is a bad engineering design if you ask me, as it gets weak over time. The transmission oil intercooler also failed all at the same time. I was only at 175k on the motor when that happened. I had to have it towed and after diagnostic found that the entire egr system and oil intercooler system failed. I ended up doing a full bulletproofing to the tune of $7k to get it back up and running. Hopefully it isn’t as drastic for you but it sounds like my experience.
PowerPunisher is offline
post #4 of 7 Old 04-15-2019, 07:47 AM
Sock Puppet's Avatar
Quoted: 516 Post(s)
Please disregard.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #5 of 7 Old 04-15-2019, 08:09 AM
california deplorable
john galt's Avatar
Quoted: 2971 Post(s)
being an 03 my first thought is the hpop and or orings
but that should have saturated the valley pretty good...
do you have a bpd oil cooler or anything that could offer hp oil a hose or something to rupture?
if it seems to be running from the back more than the front it may still be the hpop or something and it just found a way out before filling the valley?
from what you describe it sounds to me like it's hpo related
let me get my second cuppa and maybe the synapses will start to connect and i can be of more help otherwise here is a
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #6 of 7 Old 04-15-2019, 08:12 AM
john galt's Avatar
oh and IF you wind up replacing the hpop which seems fairly likely to me at present
corey at cnc fab
terminator or
adrenaline...
ask me how i know
I like mead
post #7 of 7 Old 04-15-2019, 09:00 AM
Quoted: 516 Post(s)
Sorry, I missed that it was an '03.
