Radiator shot? Full top seal leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-21-2019, 07:00 PM Thread Starter
OleMissRbl's Avatar
I recently bought this ‘05 F250. It was leaking a few drops of coolant per day, and I put some dye to try and find it, but I think I either damaged the radiator by putting body weight on it while changing the FICM, or it just happened to crap out. It’s leaking ~1oz per day now. Is there a way to repair this, or should I just replace it? If replace, OEM or aluminum?
ID:	716545   Click image for larger version
ID:	716547   Click image for larger version
ID:	716549   Click image for larger version
OleMissRbl is offline
post #2 of 3 Old 03-21-2019, 07:26 PM
voodooridr's Avatar
Quoted: 812 Post(s)
I wouldn't waste any time or money on trying to patch a factory radiator, I'd replace it with either a BPD radiator or one from Performance radiator
https://www.bulletproofdiesel.com/al...r_ford_6.0.htm
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #3 of 3 Old 03-21-2019, 07:37 PM
Quoted: 230 Post(s)
Garage
You can try re-crimping the "fingers" along the top tank, but it is just to buy time while you get a new radiator. Over heat, over pressure, or sometimes just time causes the crimps to loosen.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Found oil leak NastyNate12 6.7 Motor Problems (2011-2016) 4 08-22-2017 12:27 PM
Stop Oil Leak - Main Seal and Bed Plate erniek70 6.0L Problems Forum 4 11-03-2016 10:46 AM
99-03 7.3 oil leak diagnosis Marty 99-03 7.3 Repair Help 2 03-25-2008 04:24 PM
Rear engine seal leak huck 6.0 Motor problems 8 01-03-2006 06:57 PM
