Front cover water bypass outlet on a 2003 6.0l - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 16 Old 09-04-2018, 12:38 PM Thread Starter
Rebuilding a 2003 6.0l. The front cover was toast due to lifter failure, ran those bearings right through. Stripped old cover and got rid of it not realizing that the new aftermarket cover did not come with the water bypass tube. The outlet is between the thermostat housing and lower outlet. I have searched high and low to find just that outlet tube with no luck. I do not want to buy another front cover. Anyone know where to find one or a part #?
enterprisingtom is offline
post #2 of 16 Old 09-04-2018, 12:57 PM
voodooridr's Avatar
Quoted: 848 Post(s)
It should be a 3C3Z-8592-AB
Disregard that, the fitting between the thermostat and the lower outlet is part of the cover on the O.E. part
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #3 of 16 Old 09-04-2018, 01:11 PM Thread Starter
Wished I had spent the extra $$, to not have to deal with an "OEM" replacement part.
post #4 of 16 Old 09-04-2018, 01:20 PM
ZMANN's Avatar
Quoted: 3784 Post(s)
I hate that
6.0 flush pdf
ZMANN is offline
post #5 of 16 Old 09-04-2018, 01:28 PM Thread Starter
Spent two days now looking for just that part. I am thinking I am going to need to buy a used cover. Does anyone have one? It can be toast as long as the outlet is fine.
post #6 of 16 Old 09-04-2018, 08:39 PM
backhoebill's Avatar
Quoted: 1224 Post(s)
Send a message via Yahoo to backhoebill
I wonder if @junior125 has one
Sent from my iPhone using Tapatalk
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #7 of 16 Old 09-05-2018, 04:11 AM
voodooridr's Avatar
Quoted: 848 Post(s)
Does your aftermarket cover have a threaded hole in that spot or is it a smooth hole for a press in tube? Could it be that whatever company that made it just forgot to press in a tube?
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #8 of 16 Old 09-05-2018, 04:45 AM
Fummins Mod
junior125's Avatar
Quoted: 2148 Post(s)
Garage
you're talking about the pipe that has the one bolt retainer for the heater core line correct?
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #9 of 16 Old 09-05-2018, 05:02 AM
G8orFord's Avatar
Quoted: 2448 Post(s)
Garage
I'm pretty sure he's talking about the nipple in the attachment.
If it's not already threaded, I'd probably tap it and put a brass nipple on it. If it is already threaded... well same thing.
john galt and voodooridr like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #10 of 16 Old 09-05-2018, 08:18 AM Thread Starter
Thanks for the lead.
