FICM health check - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By voodooridr
  • 1 Post By G8orFord
post #1 of 7 Old 07-10-2018, 06:16 PM Thread Starter
FICM health check
Hi, I have a 2006 f250 6.0 with 210,300 miles the ficm is reading 46.5 to 47.5 volts on my edge programmer. This is a replacement unit by ford at 90,000 miles. Should i be concerned as i don't see 48v anymore? 1 battery was at 13.4v and the other 13.6. They both have been changed. At what point should i look to change it again?
s91ford is offline
post #2 of 7 Old 07-10-2018, 06:32 PM
SparkyF250's Avatar
Quoted: 3232 Post(s)
Garage
I'd be looking into that asap, have the batteries load tested first, then the alternator. If you still read voltage under 48, give FICM Repair a call. Low FICM voltage can destroy injectors.
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #3 of 7 Old 07-11-2018, 05:44 AM
backhoebill's Avatar
Quoted: 1245 Post(s)
Send a message via Yahoo to backhoebill
Ford specs say the FICM is considered good if the volts are above 45, I believe.
Sent from my iPhone using Tapatalk
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #4 of 7 Old 07-11-2018, 05:48 AM
Fummins Mod
junior125's Avatar
Quoted: 2190 Post(s)
Garage
@s91ford anything above 45 is "ok" by spec
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #5 of 7 Old 07-11-2018, 05:50 AM
voodooridr's Avatar
Quoted: 954 Post(s)
Ford has said a lot of questionable things to avoid responsibility throughout the years
Sent from my SM-G960U using Tapatalk
SparkyF250 likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is online now
post #6 of 7 Old 07-11-2018, 06:11 AM
SparkyF250's Avatar
Garage
I stand corrected, but it'd still make me nervous
Sparky
post #7 of 7 Old 07-11-2018, 06:20 AM
G8orFord's Avatar
Quoted: 2518 Post(s)
Garage
If it's at 45v now, it's only going to get worse over time, IMO. I'd be proactive if I were you and get it upgraded with Ed or otherwise replaced with a quality option. Also a good idea to check and/or upgrade the battery/alternator wiring while you're at it.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
