Turbo is most likely dying? - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 16 Old 10-05-2017, 09:45 AM Thread Starter
Quoted: 6 Post(s)
So, my turbo started making a high pitch squealing noise more noticeable at higher boost levels. It still makes boost like normal, and I haven't noticed a loss of power just the new noise. Also, when I shut the truck off this morning, as the turbo wound down, it made a sound I would associate with a starter going bad. It sounds horrible. I haven't started the truck since then, but it makes me think it's about to grenade on me. The truck is a 2005 F-250 CCSB. Has been fully bulletproofed, has a 4" Turbo back straight pipe, and an SCT Livewire TS+ for monitoring and programming. Also has 215000 miles on the ticker. I tow a 5th wheel with a gooseneck adapter every so often and a Kubota tractor along with some other lighter loads. I'm thinking I'm just going to replace the turbo altogether, but was think about spending a little extra money to get a better turbo. I want to keep my towing ability, but also like to have fun and go fast from time to time. I don't have any plans to upgrade the fuel system anytime soon, but if I did I wouldn't go with crazy injectors, 155 or 175 at most. Any advice on which route to go would be appreciated. Thanks in advance.
oxthegrunt is offline
post #2 of 16 Old 10-05-2017, 02:35 PM
Quoted: 36 Post(s)
I believe a repair kit should do it if you fix it soon enough.
I'd take the intake pipe out and feel for play on the wheel. Check if the blades are indeed touching the housing. If they aren't a rebuild will probably save it. If they are you can get a new upgraded wheel, or a new turbo. KC turbos is always a good stop and they have quite a few options that will retain towing ability.. @peixinho
GusCO is offline
The Following User Says Thank You to GusCO For This Useful Post:
comvet42 (10-06-2017)
post #3 of 16 Old 10-05-2017, 07:30 PM
ChrisSki's Avatar
Quoted: 587 Post(s)
When peixnho replies, his shop can help. I thought it was Phoenixho though. If you're looking for a reason to get a turbo, this could be it.
I'm relatively stock and would like to see lower EGTs. A turbo in some cases lowers temps, other cases the same turbo won't. Yearly inspections make a turbo back straight pipe not an option. I'm replacing an exhaust manifold because it's leaking, and most people report this bringing EGT's down. Afterwards if temps are higher than I'd like, could be a turbo myself, if mine were looking like it was going to go, I'd get a new the turbo sooner than I thought.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #4 of 16 Old 10-05-2017, 08:20 PM Thread Starter
Quoted: 6 Post(s)
I think it's the bearings that are toast, not really sure though. I had told myself that if anything happened to the turbo I was gonna replace it instead of rebuilding. It's not a bad truck at all and I plan on keeping it for the long haul, at least another 5-10 years and want it to be as solid as possible. I was mildly researching the powermax prior to the current issues, but have heard that some people are seeing slow spool times. Was worried that would affect towing. A lot of posts I've seen show people recommending the KC turbos, but I didn't know if the extra 300-400 over the powermax was worth it? Considering the powermax is already about 300-400 north than a stock turbo?
post #5 of 16 Old 10-06-2017, 03:58 PM
Quoted: 7 Post(s)
I had a shop install a powermax. Way too loud for me. Two weeks later I replaced it with a KC TurboTax Stage 1, and immediately noticed a big difference. Quicker spool up and just smoother as you stay on the throttle. Very pleased with it highly recommend one. The pmax is listed in the classifieds.
Sent from my SM-T560NU using Tapatalk
peixinho and john galt like this.
2006 F250 Lariat Crew 4x2
KC Turbos Stage 1
4" Flo-Pro Exhaust w/Twister Muffler
Deleted
Blue Spring
SCT X4
Current Tune: Looney
Atlas 40 FICM Tune
tnscoutr is offline
post #6 of 16 Old 10-06-2017, 04:41 PM
backhoebill's Avatar
Quoted: 1273 Post(s)
Send a message via Yahoo to backhoebill
KC Stage 2 R. This is the only turbo that pulls like a madman and still spools like stock. I put my stock turbo with a billet wheel back on, and it runs great, but my egts are higher, and it falls flat after a decent bottom-to-mid pull. I can get on a freeway onramp and merge with traffic at 65 pulling 9k trailer. But egts will hit 1400+. With S2R turbo I may hit 1300+ and be passing traffic.
Sent from my iPhone using Tapatalk
john galt likes this.
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #7 of 16 Old 10-06-2017, 05:26 PM
Quoted: 376 Post(s)
Garage
I have a good stock one with 130,000 miles on it 300$ + Shipping if you don't want to spend to much on a new one or a rebuilt just a thought
New 2019 F350 CCLB Platinum
Last Truck 2006 F350 CCLB KR
I'm out old man. I'm just a pecker-wood who lives in the woods with too many guns. Ya happy?"
BridgerMT is offline
post #8 of 16 Old 10-06-2017, 06:35 PM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
Does that mean you paid for it with your income tax refund???
2018 F250 4X4 CC LB 6.2
2004 F250 4X4 CC SB Sold (Miss you Sarah!)
DMc is offline
post #9 of 16 Old 10-06-2017, 07:27 PM
Quoted: 7 Post(s)
Now that is funny! Stupid auto-correct...
KC Turbos Stage 1
Deleted
Blue Spring
SCT X4
Atlas 40 FICM Tune
tnscoutr is offline
post #10 of 16 Old 10-06-2017, 07:48 PM
california deplorable
john galt's Avatar
Quoted: 3173 Post(s)
i am trying to save for an s2r from charlie at kc turbos
best of al worlds really. i plan to install one as soon as i possibly can...
in the mean time
running an mtw stage 2 now and it is amazing top end but a little laggy towing.
backhoebill likes this.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
