Oil temperature too high - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 36 Old 08-14-2016, 07:25 PM Thread Starter
Quoted: 3 Post(s)
I have a 2004 Ford F-250 with the 6.0. 150k miles. Lifted on 35s. It has an external oil cooler with the filter relocation, coolant filter, arp studs, an edge tuner that I always leave on the stock setting. Does NOT have the egr delete kit. When towing my boat in 100 degree Arizona weather which weighs about 4500 lbs at 65mph at 2200 Rpms my oil temperature gets as high as 240 degrees. Any ideas of what's causing it or what I could do to fix it?
Bvalcore is offline
post #2 of 36 Old 08-14-2016, 08:23 PM
djmaguire's Avatar
Quoted: 1588 Post(s)
Garage
If you are at 2200RPM at 65mph, you do not have stock 3.73 differential gearing. You must have a 4.30. Your delta is never going to match up with the stock boys, even if you weren't pulling a load in 100 deg heat.
You might try running unloaded on a flat run at 1900RPM to get a more useful measure of your delta. But... even then you might find that your cooler is fine and you still have those high temps when loaded and in heat at highway speeds. In that case, it's air-to-oil time.
Edited to add...
It's air-to-oil time if you can't live with the temp. An EOT of 240F (250F-265F in the pan) is fine for a synthetic. So, really, this is more about what you are comfortable looking at than what the oil can stand.
I am assuming that you have a Ford OEM oil cooler. If you have a Dorman/Sinister/eBay/whatever in there, swap that out and the EOT will come down.
Since you have a relocation, one other option is that you could swap the existing oil cooler out with something higher than 100,000BTU/hour. That suggestion is purely theoretical, though. I have considered it out of pure science. As far as I know, nobody has ever done it.
Good luck.
pphelps likes this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLink™ LX, Autometer EGT
djmaguire is offline
post #3 of 36 Old 08-14-2016, 08:55 PM Thread Starter
Quoted: 3 Post(s)
I'm not 100 percent sure but I think it's a sinister cooler considering everything else is sinister. Considering that I'll look into a replacement. I'm just paranoid considering it's a 6.0. I'm just running a generic 15-40 oil. Not synthetic.
Bvalcore is offline
post #4 of 36 Old 08-14-2016, 09:15 PM
djmaguire's Avatar
Garage
I completely get your concern.
The Sinister coolers were made with larger coolant passages to reduce the potential for clogging. The problem is that - because the coolant moves through the cooler more quickly - it does not transfer as much heat from the oil. Based on what I have read, you might grab an instant 20F reduction in EOT just by switching back to the OEM cooler. With that switch, you have the heightened obligation of keeping your cooling system clean. Switching to ELC if you haven't would be even better - especially with the EGR in tact. Ford Gold and high EGR cooler temps are not a good match.
Conventional oil scorches at lower temps. If you plan on putting off an oil cooler swap or otherwise doing a lot more running at those temps, I'd swap to synthetic.
2004 F550 CC Lariat
post #5 of 36 Old 08-15-2016, 05:54 AM
G8orFord's Avatar
Quoted: 2595 Post(s)
Garage
Pictures of your oil cooler setup might help. Sinister does not make/offer an external oil cooler with filter relocate that I'm aware of.
pphelps likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #6 of 36 Old 08-15-2016, 08:49 AM
djmaguire's Avatar
Garage
Good suggestion. I was interpreting what he was saying as him having a Sinister oil cooler mounted in an IPR (or BPD) relocation system. Pics would explain a lot.
2004 F550 CC Lariat
post #7 of 36 Old 08-15-2016, 10:02 AM
portcity_gt's Avatar
Quoted: 1617 Post(s)
Hell it might already have an air to oil on it, I've seen a trend of lifted trucks having air flow issues.
In for pics.
djmaguire likes this.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #8 of 36 Old 08-15-2016, 02:23 PM Thread Starter
Quoted: 3 Post(s)
It's hard to see, it is a bullet proof brand filter relocation. So the cooler is prolly as well. It's all tucked inbetween the intercooler and the ac condensor.
Do you think synthetic oil would reduce enough friction to keep the oil temp down?
ID:	557554   Click image for larger version
ID:	557570   Click image for larger version
Bvalcore is offline
post #9 of 36 Old 08-15-2016, 02:41 PM
Master_Chase's Avatar
Quoted: 520 Post(s)
Yap that's BPD hmm I wonder if maybe something is blocking the cooler(s) because the temp shouldn't be that high.
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #10 of 36 Old 08-15-2016, 02:49 PM Thread Starter
Quoted: 3 Post(s)
I need to do a coolant flush and try synthetic oil. I'm out of ideas. And it cools right down the second I pull over . I don't get it. Almost like the motor is working too hard.
Bvalcore is offline
