Truck (And Boyfriend) Problems. '07 6.0 ICP Sensor Stuff - Page 13 - Ford Powerstroke Diesel Forum
 173Likes
post #121 of 129 Old 06-06-2016, 06:55 AM
JER-1's Avatar
Quoted: 18 Post(s)
Originally Posted by BastilaShan View Post
So after changing the crank sensor I drove around a few days without indecent, yesterday after driving it a while it lurch/sputtered when I braked,
Today it SHUT OFF when i stopped, crunk up just fine, drive it a bit, and it FREAKING SHUT OFF when I stopped again. I kept the RPMs high and got it home, the RPMs wanted to sway up and down even though I was steady on the gas.
Took it to a local guy just to see what he said. The conversation was like "ICP sensor? Did it. Crank sensor can... did it. You can clean the mass air flow sensor and... already did it. The fuel filters can... changed 'em...." he said he can look at it tuesday but I dunno.
I just don't know cowboys.
I need the truck running but it's wearing me out.
TL;DR truck shutting off when stopping, RPMS swaying up and down a bit. Wat do?
Fimc power side eady do it yourself. Get dorman power side at advance auto parts.
Use code trt30 online get 30% off buy online pickup in store. Bout 79 bucks
JER-1 is offline
post #122 of 129 Old 06-06-2016, 06:55 AM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
Originally Posted by Timbo_Slice View Post
What kind of moron runs out on a girl like this? She drives a diesel truck and works on it herself. And she smells like diesel. Whaaaaat.... That's the marrying kind right there.
Very true Kimbo... For others about to pile on, let's not derail this into a dating service thread.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #123 of 129 Old 06-06-2016, 07:40 PM
ChrisSki's Avatar
Quoted: 554 Post(s)
Think the mechanic should have said something like lets hook it up to the computer for $100 diagnostic . Kind of sounds like he wants to throw parts at it starting with cheapest common fixes instead of troubleshooting. After all, good diagnostic tools are pricey especially if you can sometimes guess right.
The good shops will have diagnostic software so much better than our monitors, and if it passes, they will know to check the fuel system or whatever to fix the problem.
ChrisSki is online now
post #124 of 129 Old 06-13-2016, 12:48 PM Thread Starter
Quoted: 14 Post(s)
Can somebody walk me through the process of changing the crank position sensor? Took it to an expensive mechanic he said it looks like the guy tried to jam it in without dropping the AC compressor so he broke it putting it in and I can't pay the $1,300 for them to replace it so I guess I'm towing it back (oh yea, did I mention it doesn't start now?) and just taking a swing at it myself. It's hard to find a video of someone doing this specific sensor on this specific truck.
BastilaShan is offline
post #125 of 129 Old 06-29-2016, 04:04 AM
JER-1's Avatar
Quoted: 18 Post(s)
Get it going
JER-1 is offline
post #126 of 129 Old 06-30-2016, 01:23 PM
WD40's Avatar
Quoted: 40 Post(s)
Wow, little lady you been though the ringer on this one. Hope you are back on the road and all is well by now.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #127 of 129 Old 06-30-2016, 07:26 PM
Quoted: 692 Post(s)
little late here but you don't need to touch the ac compressor to do the ckp. 1300$ is ridiculous.
i just can't wrap my head around the logic sometimes. i mean suspicions are great. but prove the damn thing out first before following through with it
WD40, john galt and Heavy_GD like this.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #128 of 129 Old 07-01-2016, 06:36 PM
JER-1's Avatar
Quoted: 18 Post(s)
School some of us on how to change the CPS without removing the ac compressor, please.
Might need change mine out, sure beat sucking out freon , removing and replacing.
JER-1 is offline
post #129 of 129 Old 07-01-2016, 06:50 PM
Quoted: 692 Post(s)
i believe the use of an 8mm quarter inch drive swivel socket makes it easier. that and just the right length extension. it has been awhile but i do recall not having to remove anything to swap. hardest part is disconnecting and reconnecting it, IIRC. not saying it's a fun job. but you can definitely get it in and out without removing anything
john galt likes this.
-Michelangelo
kaya is offline
