My quest for (as close to 2008+ factory) fully functioning 08-12 power mirrors... - Page 59 - Ford Powerstroke Diesel Forum
 23Likes
post #581 of 592 Old 01-25-2018, 05:17 PM
i was thinking of putting a puddle light in the bottom of the mirrors and utilizing the memory wires for that. Anyone thought about this?
aevette is offline
post #582 of 592 Old 01-25-2018, 06:12 PM
i like this setup and i because of this my plan has changed.
aevette is offline
post #583 of 592 Old 01-29-2018, 11:01 AM
I've installed the 08+ mirrors on my truck and in the process of installing switches and wiring. Thought I read somewhere, maybe a different forum, about a template for the 08 style mirror switch, but can't seem to find the information now. I've been searching for a template to reduce the chances of over cutting the switch opening.
Has anyone found a template in the past?
Thanks
LowTimer is offline
post #584 of 592 Old 01-29-2018, 01:10 PM
Quoted: 63 Post(s)
I used info from this thread when I did my mirrors.
https://www.ford-trucks.com/forums/1...ock-parts.html
Dave
02 F350 CCLB Lariat 4x4 auto
285,000 on the clock
dieselsite trans filter coolant filter
diy ccv catch can with return line
6637 filter
Stancor GPR
6.0 tranny cooler
4" Diamond Eye K4318S-RP exhaust
riffraff regulated return
dual alt.style upper rad. hose
05-07 head light mod
PHP Hydra
Alliant Power 160 single shots
WW2
HPOP hoses and cross over hose from Corey
3 gauge A pillar gauge pod with EGT, trans temp and boost gauges. Autometer ford matched gauges.
glow plug light installed in gauge pod.
A/C mod
Banks Exhaust brake and Smart Lock
08 Power fold power extend mirrors
Riffraff manual lower dash panel
welove2drive is offline
post #585 of 592 Old 01-29-2018, 03:25 PM
Thanks, I'm using information from that thread as well. I don't have the 08 bezel to trace a switch pattern to cut in my bezel. I thought I read someone had made a switch template, but I'm not having any luck finding any templates if they exist.
Thanks again for the link to the thread.
LowTimer is offline
post #586 of 592 Old 01-31-2018, 05:16 PM
I wanted to post an update to the installation of a '08 mirror switch in place of my '99 mirror switch. I looked for a template without success, but discovered a round circle works as a template. I measured the width of the '08 switch housing that sits below the bezel, best I remember it was 1 3/8". Cut the circle out of a piece of paper and then use it to choose the best placement over the existing cutout keeping the gaps in the bezel from the old switch equal distance to the circle. Mark around the circle and then cut the bezel. When I placed the '08 mirror switch into the enlarged hole, all gaps from the old switch are hidden by the mirror switch bezel.
Thanks for all the helpful information that made this project possible.
LowTimer is offline
post #587 of 592 Old 02-25-2018, 11:35 AM
I wanted to post an update to my mirror upgrade. I purchased mirrors from 1A Auto for this upgrade and used information from this thread to complete the project. While purchasing parts for this project, I emailed 1A Auto about my mirror upgrade and adding additional mirror features not installed on my truck. At one time, I considered removing the connector from the 1A Auto mirror to ease the wiring, but was advised by 1A Auto not to remove the connector from the mirror to maintain my warranty. I didn't remove the connector or modify the 1A Auto mirrors and made a connector from the instructions here. After my mirrors were installed and wired, the passenger mirror folds slower than the driver side mirror. I contacted 1A Auto to inquire if this was normal operation. Instead of answering my question, 1A Auto keeps responding that my warranty is void since I added additional wiring to my truck although I made no modifications to the 1A Auto mirrors. When I wired the mirrors, everything worked as planned the first time, there were no wrong connections.
The main purpose of this update is to give others a heads up that 1A Auto is voiding the warranty if you add features such as fold, heat, turn signals, etc that was not originally installed on your vehicle. The 1A Auto description states some features may not work correctly if not originally installed on the vehicle not the warranty will be void.
LowTimer is offline
post #588 of 592 Old 09-12-2019, 07:30 AM
hey! i was reading over your guises diy type of installment and i was wondering how long the process took? im only asking cause im not very handy lol and dont want to take forever if i were to do it myself
CindyW is offline
post #589 of 592 Old 09-12-2019, 07:52 AM
It took me a couple of days but I took my time. I also used the matching plugs for the 06 harness. I have plenty of extra matching plugs and pins. I could sell you the "plug kit" if you like. I would make sure you find the factory power folding relay. I also used the factory telescopic switch mounted on my dash. See previous posts.
Amarillo6oh is offline
post #590 of 592 Old 09-13-2019, 05:04 AM
utah350's Avatar
I did mine over a weekend. Took about 6 hours of total dedicated time.
utah350 is offline
