My quest for (as close to 2008+ factory) fully functioning 08-12 power mirrors... - Page 51 - Ford Powerstroke Diesel Forum
 24Likes
post #501 of 592 Old 09-12-2015, 01:20 PM
I'd tried to make adapters for the mirrors them selves however, the only way to get the 05 side is through the ford repair pigtails (Can not seem to locate the individual pins, I did find the connectors though but you have to order a MASSIVE minimum of them) and those wires are JUST BARELY too big to fit into the connectors/pins I got from mouser, No way in h*ll can you get 2 wires into the one for the common left/right/up/down wire. Due to how I'd tried to do it i figured i'd remake them but since I had everything working (although I do have to fix the polarity with the open/close fold button which will affect the left/right up/down movement) I haven't gotten to it yet.
___________________________
1999 F150 Lariat 4.6 SCab 2WD
2005 F350 Lariat KingRanch FX4 6.0 SCrew-8Ft
^ Electrical Gurus, Advice needed @ v. Please PM me.
My Sig - Mods and Such
Ace_boy2786 is offline
post #502 of 592 Old 10-09-2015, 06:44 AM
jimmyv13's Avatar
Quoted: 49 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
I'm getting ready to tackle this...is there a way to test a mirror that is not installed on a truck to verify all of the functions operate properly before purchasing?
2015 F250 CCLB Lariat Ultimate
jimmyv13 is offline
post #503 of 592 Old 10-19-2015, 02:13 PM
Motor Head.
robertc68's Avatar
Quoted: 91 Post(s)
Originally Posted by ETuck View Post
Aceboy,
I ordered the same connectors Amarillo mentioned from Mouser.
Pins:
2-1419158-5 TE Connectivity / AMP | Mouser
Connectors:
2-1419158-8 TE Connectivity | Mouser
These came in today, I'm still gathering up the rest of the parts.
I have a question, are these the connectors that plug right into the mirror? thanks....
Hope to get this one done in the next week or two.
I already have the 2014 PF/PT mirrors mounted on the truck,
but not connected currently.
I'm attempting what I mentioned in a previous post, using the same type of switch as the power sliding rear window for my PT.
The switch will be mounted in the bezel between the mirror switch and power window master switch.
I think I've finally wrapped my head around all the wiring diagram info.
Thanks to all contributors in this thread, especially the OP.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.KC 2R turbo,2011 rear leafs,13 tailgate,flight fab trac bars. Power/folding/Extend mirrors.
robertc68 is offline
post #504 of 592 Old 11-10-2015, 10:39 AM Thread Starter
Dante04SRT's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Yes, using my wiring diagram, find the wires for the power fold and power telescope. Then just apply +12V to them. Just reverse polarity to test the opposite movement.
-Brian
2005 F350 6.0 CC/SB Lariat 4x4
EGR Delete
ARP Studs
All updated Ford internals
Edge Insight CTS2
Swamp's 58V FICM
SCT X3
TGC 2.5" Level Kit
Zerex EC-1 ELC
08+ Step Tailgate
08+ All Power Mirrors (Factory Functions, too)
2011 Rear Bumper
B&W Turnover Ball
8oz Stanadyne Performance w/each fillup
Dante04SRT is offline
post #505 of 592 Old 11-10-2015, 11:06 AM
jimmyv13's Avatar
Quoted: 49 Post(s)
Ok, thanks. The mirrors tested all good. I've gathered all of the necessary parts including the OEM extend switch. I'm hoping to find a location for it to keep the OEM look. My last resort is to put it next to the power pedal switch. I know it's an undermount switch which of course complicates things.
jimmyv13 is offline
post #506 of 592 Old 12-29-2015, 07:53 AM
jimmyv13's Avatar
Quoted: 49 Post(s)
Originally Posted by Amarillo6oh View Post
Getting there....
I'm hoping to mount the power extend switch exactly like you did. Any tips? Looks relatively simple, cut the hole and epoxy the frame for the switch to the gauge bezel.
jimmyv13 is offline
post #507 of 592 Old 03-09-2016, 08:21 AM
smarty39's Avatar
Quoted: 25 Post(s)
Garage
Has anyone used the OEM power extend switch in an 05-07 truck yet? I have a full 2012 interior so I already have the switches and pigtails...just looking for wiring schematic confirmation.
I have my mirrors installed on the truck with the extra wiring run through the dash for the power functions, just need to wire them up. I am good to go on everything aside from using the OEM power fold switch which I haven't seen anyone use yet.
Thanks!
2007 F-350 XLT FX4 - 6.0 CCSB
Studded, EGR delete, aFe 4" turbo-back exhaust, Firestone bags w/ onboard compressor, 2012 Lariat interior (seats, flowthru console, door panels, dash, & ALL trim) 2012 step tailgate, 2012 front & rear bumper, 2012 full-load tow mirrors
Tow machine for 32' Puma TT
smarty39 is offline
post #508 of 592 Old 03-13-2016, 06:36 AM
Quoted: 5 Post(s)
Switch part number
Getting ready to tackle this, lots of great information. Anyone know the part number for the OEM power sliding switch people are using for the mirror extend. I would like to put this in the bezel.
Thanks
tritom45ca is offline
post #509 of 592 Old 03-15-2016, 06:55 PM
smarty39's Avatar
Quoted: 25 Post(s)
Garage
Got everything run and wired up but can't seem to get the power fold/power telescoping to work. All 'normal' mirror functions work (L/R, U/D, lights, heat, etc) but I think I am messing up the relay wiring somehow. Can you steal power from the existing power wire (in the mirror harness) for the relay power, or does it have to be on its own circuit?
TIA!
smarty39 is offline
post #510 of 592 Old 03-16-2016, 09:12 AM
smarty39's Avatar
Quoted: 25 Post(s)
Garage
Got this sorted last night and now have FULLY functioning mirrors with all OEM components (I have 08+ door panels installed). Couldn't be happier with the outcome and the mirrors are a substantial upgrade from a viewing area perspective.
Thanks to all for posting the 'how-to' info...don't think I could've done it without
smarty39 is offline
