Stock stereo question - Page 4 - Ford Powerstroke Diesel Forum
 6Likes
post #31 of 34 Old 08-12-2018, 11:24 AM
Quoted: 133 Post(s)
Originally Posted by Dreamdrummr View Post
Are these units compatible with IPhones? They really sound like a great product.
I think some that are newer than mine might support apple car play. You’ll have to look specifically for that feature mentioned though. Some say they support apple air play but not the same thing as no control or screen mirroring.
Ross
2006 f-250 CCSB king ranch diesel 4x4. Stock w/ air bags, rancho 9000s, and coolant filter.
Rossterman is offline
post #32 of 34 Old 08-12-2018, 11:34 AM
Quoted: 9 Post(s)
Thank you for the info. It all seems complicated to me, but Im here learning all I can. Lots of great info...
Dreamdrummr is offline
post #33 of 34 Old 08-12-2018, 04:49 PM
G8orFord's Avatar
Quoted: 2544 Post(s)
Garage
There is some code written in the unit that it won’t allow connection on Bluetooth OBD2 dongles unless they have a specific name- e.g. “joying obd2” so if yours has a different name, it won't connect. Several have modified the headunit’s code to delete (xda developers forum has lot’s mods and hacks for these) this limit and some have modified the dongle’s code to change the name match joying’s to work. I gave up on their crappy dongle and just went with a wifi one since I don’t run the radio connected to the internet most of the time.
So the units aren't locked down and are hackable then. At least that's a positive. I haven't messed rooting or any other android hacking in a few years, but used to do it as a hobby. Not a real hacker per se, but more of a "ok that guy opened the door, so I'm going to see what's in there." I think it's quite humorous that most of the best parts of both Android and iOS in their most recent versions have been available through hacks for years and that a lot of the security and dependability of both systems have ome from the same people.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #34 of 34 Old 08-12-2018, 08:38 PM
Quoted: 133 Post(s)
Yeah, there’s lots of folks modding their units to overcome some poorly written code and allow better functionality. In some cases though, some have bricked the unit so not totally foolproof or for those not well versed in making these kind of mods.
Ross
