My 6.7 fuel pump install - Ford Powerstroke Diesel Forum
 66Likes
post #1 of 198 Old 07-15-2015, 04:47 AM Thread Starter
Merc82's Avatar
Quoted: 389 Post(s)
Did a lot of work to the truck last year including the addition of 190/30 injectors and a custom regulated return woth a fuel bowl delete and with fuel being fed from the rear of the heads. Previously I had installed a 6.4 pump before my HFCM. After I got the truck back together and added a fuel pressure gauge, I saw that I would drop from 60 to 40 psi on a WOT run. Which leads me to this, after comptemplating a custom Fuelab setup I decided to chose the 6.7 pump. Here is the parts list for what I have gathered to build my system. I listed where I picked everything up from as well. My system is going to tie into the custom regulated return I built with 6AN hose. My plan for fuel flow is as follows: Sump- 6.7 pump- Cat fuel filter on frame - "Y" feeding the rear of heads- existing regulated return - back to tank with 1/2 return added to factory sender. I will update as I progress.
1 PFB-103-BC3Z-9G282-E 6.7 pump only (no bracket) (Ebay)
1 BC3Z-9A335-E Bracket for the pump (Ford)
1 WPT-778 3U2Z-14S411-EUAA Pigtail for pump power (Ford)
1 84-899785K30 Mercury marine relay harness and wiring kit ( from my work)
4 716-08-08-BLK Speedflow 1/2 efi adaptor fittings 8AN (Ebay)
1 Wix 24770 fuel filter head (Amazon)
1 Cat 1R-0749 fuel filter (Amazon)
2 AER-FBM5008 Aeromotive 1/2 NPT-8AN adaptor (Summit part #)
3 FRA-209008-BL Fragola 90 8AN fitting (Summit #)
6 FRA-200108-BL Fragola 8AN straight fitting (Summit #)
1 VPE-10432 Vibrant 8AN-6AN reducer (Summit #)
1 VPE- 10807 Vibrant 8AN-6AN "Y" (Summit #)
2 FRA-871508 15ft Fragola 8AN push lock hose (Summit #)
1 Vulcan 1/25ft 8AN fire sleeve (Amazon)
1 EAR 165108 8AN to 1/2 tube adaptor (ANPLUMBING.com)
1 EAR100037 1/2 Aluminum tube 10" (ANPLUMBING.com)
1 EAR992408 8AN bulkhead nut (ANPLUMBING.com)
1 EAR983208 8AN bulkhead fitting (ANPLUMBING.com)
Chris... LBCC dirty old XL... studded and deleted, oringed heads, CCV reroute to exhaust on 5" axle dump, Odawg S3r intake, KC S2R, Holder's 190/30s, custom built R/R with 6.7 pump and Fuel lab parts, AFE/CXS intake, BD ypipe and manis, CSF intercooler, Turbosmart BOV. PMF traction bars and steering components..... almost done, I hope.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
The Following 3 Users Say Thank You to Merc82 For This Useful Post:
El_Rey_Dallas (05-13-2019), Fantom (07-16-2015), Qholic (10-08-2015)
post #2 of 198 Old 07-15-2015, 05:45 AM
Gustav17's Avatar
Love the parts list... got any pictures of the setup?
Gustav17 is offline
post #3 of 198 Old 07-15-2015, 06:15 AM
BigRedPSD's Avatar
Quoted: 3 Post(s)
Looks like a good build. Interested in pics and and how it all pans out for you, I plan on doing this in the next year or so.
BigRedPSD is offline
post #4 of 198 Old 07-15-2015, 08:33 AM Thread Starter
Merc82's Avatar
Quoted: 389 Post(s)
Thanks, no pics yet. I haven't done anything. It's my season at work so have been super busy, so finding time to do projects like this is scarce. I plan on knocking it out over a coming weekend.
Merc82 is offline
post #5 of 198 Old 07-15-2015, 01:10 PM
Jeffrey Watts's Avatar
Quoted: 25 Post(s)
Please go way overboard on pics. Pics of every detail. I'm about to start on this same thing on mine. Did I mention pics?
Jeffrey Watts is offline
post #6 of 198 Old 07-16-2015, 01:11 AM
work&play's Avatar
Quoted: 2 Post(s)
Thanks for the wright up.
I am looking to replace my Airdog II at some point.
work&play is offline
post #7 of 198 Old 07-16-2015, 09:16 AM
Master_Chase's Avatar
Quoted: 517 Post(s)
May I ask what benefits this has over an airdog or fass fuel pump?
Master_Chase is offline
post #8 of 198 Old 07-16-2015, 11:23 AM
Quoted: 25 Post(s)
It does just as good of a job, and is available at any dealership or parts store.
post #9 of 198 Old 07-16-2015, 11:31 AM
Fantom's Avatar
Quoted: 18 Post(s)
Feedback Score: 4 reviews
Looks like I got some shopping to do. Thanks for posting this!
[B]John [/B]
[CENTER]
[/CENTER]
[CENTER][B]2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI[/B]
[U][B]100,000 Miles[/B][/U][/CENTER]
[CENTER][COLOR="Red"][B]Live in Northern California? Stop in here and say hi[/B][/COLOR]
[/CENTER]
Fantom is offline
post #10 of 198 Old 07-16-2015, 12:01 PM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
What are you planning to do with the 6.7 filter? If you keep it do you have to buy the upper and lower as a set and just toss the upper one away?
Thanks for the list. You can use most of these parts and adapt it to a 7.3.
>:)[CENTER]01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
[/CENTER]
sbluke55 is offline
