No fuel pressure after parking on a steep incline? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-20-2014, 08:13 PM Thread Starter
Been meaning to get around to asking this question, but 2 months ago I had 190 injectors, regulated return fuel system, and a FASS 200gph installed. My driveway is one steep ****er. Its over 120ft long and there is over a 40ft elevation change from the bottom, to the top. I don't know what percent grade that works out to, all I know is that I hate it a little more everytime I have to bring the trash down for pickup.
Anyway, i normally pull all the way to the top and lock the e-brake first and then put it in park but that first week when I got the truck back I found 2 issues. 1st, If I let my truck get just a little below a 1/2 tank of fuel, the next morning when I cranked it, my FP gauge in the pillar will show no pressure. It cranks and idled just fine but it will take 15-20 seconds before the FP would move from 0 to 70psi.
To fix this issue, I started backing up the driveway (which is nearly impossible in the rain without turning on 4x4) so that my front end is lower than the rear. Problem never happened again after that.
Another issue that I learned not to do again is not to let it drop below 1/4 of fuel. I did once and after a quick 75% throttle run, right after I let out the FP dropped to zero. I guess the acceleration sloshed all the fuel to the back and it sucked air? So long as I'm above 1/4 and not parked with my *** end lower than the front, I never had another issue with my FP.
I'm just curious Is there anything that can be done to prevent this from happening or is that just the nature of these trucks? At least now I know that when ever I do eventually take it to the track, don't go with only 5 gallons of fuel in the tank like I've always done with my gas vehicles to keep weight to a minimum.
2007 Ford F250 CCSB - Daily Driver
KC 68mm Turbo, WPE Intake Manifold, 190/75 Inj, Reg Return Fuel Sys, FASS 200gph, 58v FICM, 4" Exhaust, Studs, EGR Delete
670RWHP / 1153RWTQ-Fuel Only
2000 Ford Lightning SVT - Weekend Toy
Built Motor, Whipple 3.4L SC, Heads, Cams, Fuel System, Exhaust, Suspension, Full interior with AC
10.9 @ 124mph on 18" Drag Radials and 93 Pump Gas
ZaC851 is offline
post #2 of 8 Old 11-20-2014, 09:16 PM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
Most likely your foot broke off your fuel pick up in the tank. Drop the tank and clean out all the pieces and replace the foot. https://www.strictlydiesel.com/p-271...up-screen.aspx
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 8 Old 11-21-2014, 02:31 AM Thread Starter
Awesome. This sounds like it may be a fix to my problem then.
ZaC851 is offline
post #4 of 8 Old 11-21-2014, 02:37 AM
Jeremy@TDA's Avatar
Quoted: 124 Post(s)
When you bring it over here i'll put a sump on it for you!
Owner- The Diesel Authority
Instagram- @thedieselauthority
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
The Following User Says Thank You to [email protected] For This Useful Post:
mossyoak (11-21-2014)
post #5 of 8 Old 11-21-2014, 02:51 AM Thread Starter
Oh that would be my preferred method. I didn't know one was made for our trucks. Hell I didn't even know that there wasn't even a in-tank fuel pump until recently...
I I'll just hold out and keep a 1/4 tank or more until then.
ZaC851 is offline
post #6 of 8 Old 11-21-2014, 03:52 AM
Merc82's Avatar
Quoted: 389 Post(s)
Sump FTW and don't look back.
Chris... LBCC dirty old XL... studded and deleted, oringed heads, CCV reroute to exhaust on 5" axle dump, Odawg S3r intake, KC S2R, Holder's 190/30s, custom built R/R with 6.7 pump and Fuel lab parts, AFE/CXS intake, BD ypipe and manis, CSF intercooler, Turbosmart BOV. PMF traction bars and steering components..... almost done, I hope.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #7 of 8 Old 11-21-2014, 05:13 AM
The 200gph pump should have been installed with a suction tube(red fitting on top of tank), it should not be pulling from the factory tubes. I am in no way saying a shop did not do a good job but if you are having issues at 1/2 tank then there is probably an issue with how the suction tube was cut, most likely too short.
A sump should solve the issue though. Should also have 5/8" line from the tank to the FASS.
FASSSpencer is offline
post #8 of 8 Old 11-21-2014, 07:13 PM
Jeremy@TDA's Avatar
Quoted: 124 Post(s)
Yep! Bean's diesel make a nice sump! That's what's on my truck. Very simple install too
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
